[solved] Array of bevelled holes in a block
instance
Post by instance »
I'm trying to create an array of bevelled holes in a box and can't figure out how to do it without resorting to macros. A simplified version of the problem is attached.
I've created the hole with a sketch and revolution:
My first thought was to make an array of these, then cut them form the box, but MultiTransform doesn't like disjoint solids. fine then, I'll make a box with a hole in it, size the box so they're adjacent and then use that.
But no, that's giving me an error: "only additive and subtractive features can be transformed".
My conclusion is that I'm just taking an incorrect approach and need to try something else, but I can't see what that might be. Can anyone offer some advice on the best way to get this done?
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
  * 3D_Printing_Tools
ArrayOfHolesProblem.FCStd
(24.7 KiB) Downloaded 13 times
Bance
Re: Array of bevelled holes in a block
Post by Bance »
instance
Post by instance »
Bance wrote: Sun Aug 07, 2022 9:11 pm Just use the hole tool.....Image
That will work for the current problem, thanks!
Still curious how I could solve this problem if the hole profile is more complicated... any ideas?
Bance
Post by Bance »
Just make the revolve a subtractive one (groove) and then pattern as usual.
instance
Post by instance »
Bance wrote: Sun Aug 07, 2022 9:19 pm Just make the revolve a subtractive one (groove) and then pattern as usual.
There, that's the light bulb moment I needed! Thanks again.
Re: [solved] Array of bevelled holes in a block
If it is even more complicated, you can also use multiple features in a single pattern operation.
