sheetmetal created extentions can not be edited in sketch
Hello together, I am new and excuse me, if I am asking stupid question. I created some shape with sheetmetal starting with polstered rectangle, but I can´t edit any of the parts in sketch mode to modify the shape. If I open it in sketch, every line I create is somewhere in the space but not in the surface I want to catch. I want to cut off diagonal the 2 edges, yellow marked.
Re: sheetmetal created extentions can not be edited in sketch
Hi and welcome to the forum!
You can attach your model here for further investigation. If you properly choose the origin of the model, it should be easy to attach a sketch to a main plane and do a pocket.
You can also try the MiterAngle of SheetMetal
- papyblaise
you can place the sketch on the general plane parallel to the face and use the external reference to limit the sketch and make a pocket "through all symmetrical" or a subtractive pad
- biais.JPG (17.85 KiB) Viewed 841 times
- biais.FCStd
- (69.61 KiB) Downloaded 9 times
- Shalmeneser
For the 1st post, you can ask stupid questions
Can you share your full version info (follow the link in the banner above).
- papyblaise
and don't be offended if some make stupid answers
I am so sorry, the version is probably the newest one, just installed on last Sunday:
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
* sheetmetal 0.2.56
In the mean time I managed to create a circle whole in this part, but the sketched triangle, I can´t remove by pocket function .
Another question, how to remove the "bendings" which are left, after I reduced the lenght of the attached bended sheet (green marked).
The file is attached for the investigation by the experts. Thanks in advance.
Jack
Installed mods:
* sheetmetal 0.2.56
Jack
- brettgriffneu.FCStd
- (42.76 KiB) Downloaded 5 times
- Screenshot 2022-08-08 231909.png (20.12 KiB) Viewed 677 times
It seems the file were not attached, once again...
- (42.76 KiB) Downloaded 7 times
Thanks a lot, but I am just beginner, this sounds like a magic for me...I can not follow your advicepapyblaise wrote: ↑Mon Aug 08, 2022 7:09 am you can place the sketch on the general plane parallel to the face and use the external reference to limit the sketch and make a pocket "through all symmetrical" or a subtractive pad
- papyblaise
the sketch must be exactly positioned at the edges of the side to be cut
- biais2.JPG (37.98 KiB) Viewed 566 times
Thanks a lot papyblaise, is there a function which I must activate the lines will snap on the edges?
