helix go out of the allowed scope?
Hello I am new ot FreeCAD and tried to follow the steps in this link https://www.youtube.com/watch?v=Sl5HAbf-8do&t=1562
and I followed it in every single step, but when I am applying the last step which is the sweeping I get this message and no grove is created on the bolt, can anyone explain what this error means?
PartDesign::AdditivePipe: Link(s) to object(s) 'Helix' go out of the allowed scope 'AdditivePipe'. Instead, the linked object(s) reside within 'N/A'.
- 2022-08-07 21_35_47-FreeCAD 0.20.png (181.56 KiB) Viewed 971 times
- 2022-08-07 21_33_07-FreeCAD 0.20.png (201.42 KiB) Viewed 971 times
Re: helix go out of the allowed scope?
Hi and welcome to the forum!
I didn't wathc the video, because it seems to be a poor one. If you want to use the helix in a PartDesign body, you either need a PartDesign ShapeBinder or you have to use the Helix as BaseFeature.
If it is not for exercising but rather to get the job done: there is also a PartDesign SubtractiveHelix.
- Shalmeneser
Following the link in the red banner above, can you provide a file and your full version info ?
Without the file :
* the helix touches itself ?
* coplanarity ?
Without the file :
* coplanarity ?
Hi chrisb and Shalmeneser,
here is the version
and I attached the file as well. I am using the subtractive pipe which seems it is working, but just not taking the part away.
here is the version
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
* Assembly4 0.12.3
- Bolt_V2.FCStd
- (228.57 KiB) Downloaded 16 times
chrisb wrote: ↑Mon Aug 08, 2022 9:39 am Hi and welcome to the forum!
Hi Chrisb,
I am not sure what you mean by "use the Helix as BaseFeature" can you please explain.
Thank you for the PDF file that this great
- Shalmeneser
Coplanarity with the upper face.
- Capture d’écran 2022-08-08 181109.jpg (36.83 KiB) Viewed 757 times
you ARE AMAZING, it worked!!!
how did you find out about that coplanarity ?
- Shalmeneser
Helix has this well-known problem with coplanarity.
Thank you so much for taking the time to look at this issue
Either select the helix before creating the body, or drag the helix into the body.
You're welcome.Thank you for the PDF file that this great
