Fillet covering entire face, rather than just specified edge
ilewismsl
Post by ilewismsl »
If I create a box and filet the four edges around the sides (FilletProblem1) or if I draw the fillet in the sketch (FilletProblem2), an additional fillet on a top or bottom edge fillets all the edges around the corresponding face, not just the edges I select.
This appears to be a defect. Fillet does not look like it is supposed to chase edges from a selected edge.
I have attached two example files that show the problem. One uses two fillets and the other draws the fillets on the sides in the sketch.
Ian Lewis
www.mstarlabs.com
Using
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
  * fasteners 0.3.38
  * MakerWorkbench
  * sheetmetal 0.2.49
  * ThreadProfile 1.81.0
FilletProblem2.FCStd
(17.88 KiB) Downloaded 13 times
FilletProblem1.FCStd
(18.94 KiB) Downloaded 16 times
Re: Fillet covering entire face, rather than just specified edge
Hi and welcome to the forum!
ilewismsl wrote: Mon Aug 08, 2022 11:19 am This appears to be a defect. Fillet does not look like it is supposed to chase edges from a selected edge.
It is indeed on purpose that fillets extend along tangential continuations. This is often very convenient, and sometimes a pain.
papyblaise
Post by papyblaise »
in example 2 it is enough to make all the threads in a single operation starting with the edge of the large face
fillet edge.JPG (18.12 KiB) Viewed 832 times
Shalmeneser
Post by Shalmeneser »
PartDesign_Fillet
Add a fillet
3. For a chain of tangentially connected edges only a single edge needs to be selected, the fillet will propagate along the chain.
adrianinsaval
Post by adrianinsaval »
That's standard behavior across most CAD or at least all I know of.
freedman
Post by freedman »
Fillet problem#1, if I add the top single edge to the original Fillet list, that seems to work.
Fillet problem #2, that seems broken, your selection is valid but the software is confused.
ilewismsl
Post by ilewismsl »
Shalmeneser wrote: Mon Aug 08, 2022 4:33 pm PartDesign_Fillet
Add a fillet
Oh. Is there any way to say "fillet just what I select"?
Is there a way to break the "tangentially connected edges" without modifying the model?
ilewismsl
Post by ilewismsl »
Clearing duplicate.
ilewismsl
Post by ilewismsl »
The replies I have here seem to indicate that this behavior is not a defect in either example I provided. It is "as expected".
So, there is no reason to file a defect. I just have to find a way around the behavior.
Is that correct?
mfro
Post by mfro »
ilewismsl wrote: Tue Aug 09, 2022 8:09 am
Add a fillet
No. The tangent edge contour creation is part of the OpenCascade fillet algorithm. If you want something else (is there a real world use case where you really want that?), you have to work around it (e.g. with a pocket or subtractive loft in simpler cases).
Cheers,
Markus
