Bug? Can't mix sketch ref with spreadsheet alias?
In attached project, I have a spreadsheet called "p" with one alias called "thickness", whose unit is in mm. I've labelled the radius of circle in the "master" as "dia". In "Sketch001" I create another circle and can set the expression for its radius as <<master>>.Constraints.dia, or as <<p>>.thickness, but I cannot set it as <<master>>.Constraints.dia - <<p>>.thickness, as I get the error shown in the pic. I can multiply these two references, which makes me think that FC thinks the p.thickness is unit-less when used with the labelled reference. A bug?
- testref.FCStd
- (7.15 KiB) Downloaded 20 times
- Screen Shot 2022-08-08 at 4.44.05 PM.png (166.57 KiB) Viewed 804 times
Re: Bug? Can't mix sketch ref with spreadsheet alias?
Not sure if it is an error, but you can give the value from the spreadsheet a unit:
<<master>>.Constraints.dia - <<p>>.thickness*1mm
- Shalmeneser
Within a Formula editor :
* <<master>>.Constraints.dia -> 10 mm
* <<p>>.thickness -> 2
They have not the same unit, so a Unit mismatch occurs.
It seems that Unit in SpreadSheet is not used inside Formula editor.
- Shalmeneser
Clicking in cell B1 in spreadsheet 'p' crashs FC in 0.21.29923.
OS: Windows 10 Version 1809
Version: 0.21.29923 (Git)
Hash: 30cb46cc5f630c97311162413b68edcff95db481
Locale: French/France (fr_FR)
Installed mods:
* fasteners 0.3.50
* fcgear 1.0.0
* Manipulator 1.4.9
* sheetmetal 0.2.53
No problem here. Does it need a special procedure such as a certain other cell to be selected before?Shalmeneser wrote: ↑Tue Aug 09, 2022 12:26 am Clicking in cell B1 in spreadsheet 'p' crashs FC in 0.21.29923.
OS: macOS 10.16
Version: 0.21.29865 (Git)
Hash: fb5c731847398c5bfbc37468ba851e70860a86d5
Locale: C/Default (C)
Installed mods:
* FC_SU
* FeedsAndSpeeds 0.4.0
* fcgear 1.0.0
* fasteners 0.3.51
* sheetmetal 0.2.56
* ExplodedAssembly
* Curves 0.5.4
- Shalmeneser
(in fact, today) Left-Clicking in cell B1 in spreadsheet 'p' freezes FC in 0.21.29923. (no problem in 0.21.29485)
I've got my eye on a commit that may have triggered this so I'll test backing it out and if so I'll raise it with the author.Shalmeneser wrote: ↑Tue Aug 09, 2022 9:49 am (in fact, today) Left-Clicking in cell B1 in spreadsheet 'p' freezes FC in 0.21.29923. (no problem in 0.21.29485)
Actually I can't replicate this with either my self compiled build or the latest AppImage, I can left click, double-click and right click in any cell without a crash or freezing. I'll boot into Windows and see how the Conda build behaves there.
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.21.29997 (Git) AppImage
Hash: b52967d52ac46eff7c59e74d991f3f5b298944ef
Installed mods:
* fasteners 0.3.50
* Silk 1.0.0
* Plot 2022.4.17
* CfdOF 1.16.1
* BIM 2021.12.0
* dodo
* Curves 0.5.4
* Manipulator 1.4.9
* fcgear 1.0.0
* ThreadProfile 1.82.0
* A2plus 0.4.56a
* sheetmetal 0.2.56
Version: 0.21.30019 (Git)
Hash: a32e92722700c8584d74e3fe3e4823fbbabba9bc
Python 3.6.9, Qt 5.9.5, Coin 4.0.0a, Vtk 7.1.1, OCC 7.3.0
Installed mods:
* fasteners 0.3.50
* Silk 1.0.0
* Plot 2022.4.17
* CfdOF 1.16.1
* BIM 2021.12.0
* dodo
* Curves 0.5.4
* Manipulator 1.4.9
* fcgear 1.0.0
* A2plus 0.4.56a
* sheetmetal 0.2.56
- Shalmeneser
@Shalmeneser, it looks to me as though this maybe specific to your config files, all OK using the latest Windows Conda build.
@psommerfeld, I'll be honest I'll have to read the Wiki to see whether there's something wrong with the documentation but, from my point of view it's simply the way you have entered the data into the cell. I can fully understand why you've put a number 2 in the Content and then added mm to the Display Unit. The Display Unit should be empty and the dimension entered in the cell as =2mm. This then allows the two sides of the subtraction to be in the same units.
My understanding has always been that the Display Unit was for things such as Bags, Barrels or Pallets, something that FreeCAD does not have in it's core Units handling (and there is a lot in it's core units when you consider all the Power, Temperature Expansion, Density of materials, I could go on ).
Edit: The Wiki corrected part of my understanding.
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Installed mods:
* A2plus 0.4.56a
* Assembly3 0.11.3
* CfdOF 1.17.7
* Curves 0.5.4
* fasteners 0.3.51
* fcgear 1.0.0
* freecad.xray 2022.4.17
* Manipulator 1.4.9
* Plot 2022.4.17
* sheetmetal 0.2.56
* Silk 1.0.0
