[Feature suggestion] Make Auto-Constraints possible from any Plane
- FredCailloux
OS: Windows 7 Version 6.1 (Build 7601: SP 1) / Word size of FreeCAD: 64-bit
Version: 0.20.29177 (Git) / Build type: Release / Branch: releases/FreeCAD-0-20
________________________________________
When setting the Auto Constraints in Edit/Preferences/Sketcher,
Tick ON Auto Constraint will not necessarily be activated when attempting to create a Polyline closed form.
I’ve included a sketch for repeating the problem.
The proposed sketch involve the attempt to make a Bolt.
When entering the “sktThread” sketch one can see that the “Edit controls” Auto constraints is selected ON.
The problem manifest ( but not necessarily limited to ) when a closed Polyline is created.
This example try to create a triangle utilizing the Polyline tool.
Because the background plane is XZ with X pointing to the right, by default, the attempt can be successful.
If the construction view is rotated on the Z axis such that X is pointing to the left (180°), then the Polyline cannot be closed.
Note: The XZ plane is rotated utilizing the upper right Navigation Cube on the sketcher window.
Trying to build a triangle utilizing the Polyline tool will result in a semi triangle for which the End of the third segment is impossible to connect with the Start of the first segment, as if the Auto-Constraints feature has suddenly been disabled.
In the previous case, where the Z axis has not been twisted 180°, there is no problem closing the triangle, where in this case the triangle is impossible to close.
If the XZ plane is rotated back to X axis pointing right, then the Polyline tool can perform correctly and closing the triangle suddenly become possible again.
Many experiments have been tried to see if there could be interactions with either, the Auto Constraints ticked ON from the preferences or within the Edit Controls from the Sketch window dialog. Both options are erratic when the Z axis is manipulated.
It would appear that the only way for the Auto Constraints feature to be functional is when no modification of the Z axis rotation has been done.
In a perfect world, it is obvious that Auto-Constraints should have nothing to do with the fact that a plane is or not rotated.
- Possible.png (137.39 KiB) Viewed 1001 times
- NotPossible.png (129.81 KiB) Viewed 1001 times
- _AutoConstraints.FCStd
- (39.26 KiB) Downloaded 7 times
Great results only comes with great understanding. Great memory is just an illusion.
Re: Cannot utilize Sketcher Auto-Constraints as expected
For technical reasons are the points in a sketch slightly elevated over the geometry. Thus they cannot be selected when editing a sketch from behind.
If you have a given - turned - drawing and you want to follow this while sketching, then you should consider to set MapReversed=true for the sketch.
- Shalmeneser
In that case, you can use a box selection (right to left) of the vertex then Sketcher_ConstrainCoincident them.
I seldom rotate the sketch while editing it : only to catch elements normal (perpendicular) to the view.
Op opened issue #7341
I'm not really happy with the ticket. The reason why we ask people to discuss issues prior to creating a ticket, is that the result of the discussion should be incorporated in the ticket. The issue has nothing to do with auto constraints. It is not a bug - albeit inconvenient -, but a feature request, because the current state is known and works as designed.
chris, Agreed.
Do you mind re-wording it so it's a feature request then ?
Will do later.
- FredCailloux
Respectfully, I struggle understanding the issue here. As far as a User is concerned, one is expected to be able to Auto-Constraint and FreeCAD does not behave as expected. To me it sound like it's a bug. But hey, You guys are the expects and I'm just a newbie, so you win. What should be the next step ? Should I just delete the ticket or edit ? What should be changed in the description ?chrisb wrote: ↑Fri Aug 12, 2022 7:32 pm I'm not really happy with the ticket. The reason why we ask people to discuss issues prior to creating a ticket, is that the result of the discussion should be incorporated in the ticket. The issue has nothing to do with auto constraints. It is not a bug - albeit inconvenient -, but a feature request, because the current state is known and works as designed.
Cheers
We don't win due to you being a newbie, we win because we are rightFredCailloux wrote: ↑Sat Aug 13, 2022 12:44 pm You guys are the expects and I'm just a newbie, so you win.
I think the issue should be something like this:What should be the next step ? Should I just delete the ticket or edit ? What should be changed in the description ?
Cheers
Description of the problem: The points in Sketcher are raised above the geometry in order to make the selectable with the mouse. This works well in the default orientation, but fails if the sketch is turned so that it is seen from the back.
Feature request: Make the points selectable with the mouse independent from the orientation of the sketch. This could e.g. be done by raising them always towards the user.
- FredCailloux
Sounds good to mechrisb wrote: ↑Sat Aug 13, 2022 11:38 pm I think the issue should be something like this:
