Crasting zig-yag line. Is there simple way?
I have to create zig-zag line with 24 peaks in Sketch. It should fit within known rectangle (already drawn construction lines).
I am looking for simple way to make it. So far it is pretty much all manual work.
Using rectangular pattern made lot of mess with constraints so I abandoned idea.
Idea to set points along a line and then create Polyline using those points failed as for some reason not all points of poly-line ended up connected so i had to go check them, and on setting Concident constraint again, constraints fell apart. things got disconnected, horizontal constraints deleted on their own... and not to mention that is was nightmare to set that number of points equally distanced.
Or maybe I am just plain stupid?
- Shalmeneser
Re: Crasting zig-yag line. Is there simple way?
Stupid only with no drawing.
Candidate to make a script if some programmer are interested in these
Hard to tell with the description.
It sounds like something for patterns or Lattice2 workbench.
There may be perfectly sensible ways to do it...if we didn't have to use a crystal ball to guess what the ultimate goal is.
And, my crystal ball is at the cleaners...
I managed to draw zig-zag line as I needed it to.
One issue is - I am making prototype, and number of peaks is not finite. If I have to change number of teeth I would have to draw it all over again, as I could not find a way to parametrize it.
Other issue is, this was supposed to be used as sketch on curved surface to get teeth on flat side of a disk part. That part does not work at all.
I've created example out of my project so I can show what is troubling me:
I am trying to crate teeth similar to these.
- papyblaise
voilà
- dent de loup.JPG (36.77 KiB) Viewed 819 times
- dent de loups.FCStd
- (119.23 KiB) Downloaded 18 times
- adrianinsaval
very common mistakes, don't make patterns inside sketcher, keep your sketches as simple as possible then do a pattern of the feature.
That was my intention but it seems Skech On Surface does not work with patterns. It requires sketch shape for all 360 degrees.adrianinsaval wrote: ↑Tue Aug 09, 2022 2:11 pm very common mistakes, don't make patterns inside sketcher, keep your sketches as simple as possible then do a pattern of the feature.
Search the forum for "Hirth joint".
