Need Help with Preference Pack
Founder
Re: Need Help with Preference Pack
Post by wmayer »
chrisb wrote: Wed Aug 10, 2022 12:06 am After applying the preference pack, the icons stay as before, but the selection list is doubled like this:
Confirmed. And each time you press the Apply button of any preference pack the more duplicates you get in the combo box. Affected are also the combo boxes for the list of style sheets and the view mode of the tree structure.
The issue is caused by the fact that DlgGeneralImp::loadSettings() is called each time the Apply button is pressed but the affected combo boxes are not cleared.
The second problem why the icon size is not applied is because the value of the parameter group isn't read from the parameters but the currently active value is used.
Both issues are fixed with git commit ff876bf72c
wmayer wrote: Fri Aug 12, 2022 12:10 pm Both issues are fixed with git commit ff876bf72c
Thanks! I will now continue searching the slow-down-culprit in my preferences.
Founder
Post by wmayer »
chrisb wrote: Fri Aug 12, 2022 1:35 pm Thanks! I will now continue searching the slow-down-culprit in my preferences.
I thought you solved it by deleting your old user config. Or do you want to figure out which setting is causing it?
wmayer wrote: Fri Aug 12, 2022 3:40 pm I thought you solved it by deleting your old user config. Or do you want to figure out which setting is causing it?
Exactly. Right now I'm at a state where I start from scratch, apply a preference pack and everything works well. After restart it is slow again.
