partial redundant constrain issue
jaessa
Post by jaessa »
I am trying to create a 4 parts circle with a diameter 80. I needed the curve bench so I installed it, but after the reboot, I am not able to constrain the 4 parts. I either have partial constrain or redundant constrain. the file is attached. Any thoughts?
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
  * Assembly4 0.12.3
  * CurvedShapes 1.0.4
  * Silk 1.0.0
4 parts Circle.FCStd
(6.17 KiB) Downloaded 19 times
Re: partial redundant constrain issue
You may have a look in one of the documents in my footer. I may later have time to fix your model. The idea is to use rather tangency and equality rather than coincidence. If you use three coincidences on the ends and center of an arc, they consume 6 degrees of freedom (DOF) while an arc has only 5.
Here is the fixed circle as described above.
4partsCircle_cb.FCStd
(5.37 KiB) Downloaded 18 times
FCuser2019
Post by FCuser2019 »
Hello, another possible solution:
4partsCircle_FCu2019.FCStd
(6.21 KiB) Downloaded 20 times
Shalmeneser
Post by Shalmeneser »
Sketcher_CreateArc (=5dof) : It's a usual problem of not overconstraining
* Arc #1 : Center + Axis + Axis (+ Radius)
* Arc #2 to #4 : Center (2dof) + Edge (2dof) + Axis (2dof)
or
* Arc #2 to #3 : Center + Edge + Axis
* Arc #4 : Center (2dof) + Edge (2dof) + near the 1st edge -> Horizontal or Vertical constraint (1dof) between first and last edge
jaessa
Post by jaessa »
chrisb wrote: Wed Aug 10, 2022 7:55 am You may have a look in one of the documents in my footer. I may later have time to fix your model. The idea is to use rather tangency and equality rather than coincidence. If you use three coincidences on the ends and center of an arc, they consume 6 degrees of freedom (DOF) while an arc has only 5.
I actually followed your advise and sure enough, I got fully constrained. I was following a video and that is what he did. Thanks for the explanation.
