Refinement of Cylindric Solid with higher Sampling (<200) crashes
blusser
Post by blusser »
As the title says:
Refinement of Mesh with higher Sampling crashes
OS: Win 10
FreeCAD: v.20
1. Create a cylindric Mesh (Radius: 40; Length: 20; Sampling200)
Then continue According to https://wiki.freecadweb.org/FreeCAD_and_Mesh_Import
2. Switch to the Part Workbench
3. Select the mesh, and go to the Part → Create shape from mesh or press the Part ShapeFromMesh button
4. Click OK in the dialog
5. Select the newly created shape
6. Go to Part → Convert to solid
7. Select the newly created solid
8. Go to Part → Refine shape or press the Part RefineShape.svg Part RefineShape button
=> Then FreeCAD crashes. No putput.
Attached is my MACRO.
You can run it.
Does anyone know the reason?
Cheers
Blusser
CreatMesh.py
(1.8 KiB) Downloaded 9 times
