DynamicData import values from constraints
tre4b
Post by tre4b »
Hi All,
I was trying to use this feature of DynamicData. I cannot seem to get anything to happen, the dialog pops up asking me to confirm I want to do this but then nothing happens.
Do any others use this workbench and if so is there a trick to getting this to happen?
I am using the most up to date version of the plugin.
TheMarkster
Re: DynamicData import values from constraints
Post by TheMarkster »
I replied to you on github. Thanks for creating the topic. I did not see it before replying there. Please attach the file you are attempting to import so I can see if perhaps you have some issue with the sketch. You should also include your full freecad information from help -> about freecad -> copy to clipboard.
tre4b
Post by tre4b »
Ta Markster,
I did not know you were on here and thought maybe I was doing something stupid ;-)
Will do it through that Issue and post back into here once it is solved so that others can see.
drmacro
Post by drmacro »
What is the issue? Seems to works as I've always used it...
Snip macro screenshot-d3a247.png (91.06 KiB) Viewed 602 times
OS: Debian GNU/Linux 11 (bullseye) (XFCE/lightdm-xsession)
Version: 0.21.30053 (Git)
Hash: c219134a1e0892e80315f41705f84bc25fe265ff
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 7.1.1, OCC 7.7.0.dev
Installed mods:
  * kicadStepUpMod 10.14.5
  * Manipulator 1.4.9
  * DynamicData 2.46.0
  * fasteners 0.3.51
  * CubeMenu
  * fcgear 1.0.0
  * plugins
  * Pyramids-and-Polyhedrons
  * Defeaturing
  * Assembly4 0.12.3
  * OpticsWorkbench 1.0.8
  * workfeature-macro
  * sheetmetal 0.2.56
  * A2plus 0.4.56a
  * CurvedShapes 1.0.4
  * Curves 0.5.4
  * workfeature
  * lattice2 1.0.0
tre4b
Post by tre4b »
Not sure it just does nothing. Probably something in my file or something. I have added more to the git hub issue.
tre4b
Post by tre4b »
As promised:
The issue that I had was my own fault. I had used spaces in my sketch naming, and also the naming of the dimensions. With those removed or replaced with underscores everything worked as advertised.
thanks to TheMarkster for helping me figure it out
tre4b wrote: Thu Aug 11, 2022 11:13 am I had used spaces in my sketch naming, and also the naming of the dimensions.
Providing a file reveals such issues extremely fast.
