I doubt that this is related. As I'm currently investigating the visual cursor thing, I have a local build that reverts that said commit (still investigating what's wrong with it as it basically looks like an innocent cosmetic change). It has the same behaviour (i.e. does not snap to the intersection although the visual cursor is fixed).Syres wrote: ↑Thu Aug 11, 2022 8:26 am Just purely the visual cursor bug with snapping in general was triggered at Git Revision 0.21.29715 on the master branch so any build before that will be OK with regard to that. I've asked Werner to give me some pointers on how to revert the commit in whole or part to fix the regression. Other bugs in the create of the geometry I can't comment on.
Can't snap Intersection where two arcs cross in Draft WB
Re: Can't snap Intersection where two arcs cross in Draft WB
Cheers,
Markus
Markus
I thought the same but, using Werner's git commit 2b5b7cd fix and creating a new file of two overlapping Draft arcs, I can snap the intersection and draw a line as I would expect.
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.21.30059 (Git)
Hash: 2b5b7cd607aa033e644729845551c16c539928db
Python 3.6.9, Qt 5.9.5, Coin 4.0.0a, Vtk 7.1.1, OCC 7.6.3
Installed mods:
* fasteners 0.3.51
* Silk 1.0.0
* Plot 2022.4.17
* CfdOF 1.16.1
* BIM 2021.12.0
* FeedsAndSpeeds 0.4.0
* dodo
* Curves 0.5.4
* Manipulator 1.4.9
* fcgear 1.0.0
* ThreadProfile 1.82.0
* A2plus 0.4.56a
* sheetmetal 0.2.56
That's something I (and others, see Thomas' post above) could do before already. With the TO's original file it still doesn't work.Syres wrote: ↑Thu Aug 11, 2022 10:14 amI thought the same but, using Werner's git commit 2b5b7cd fix and creating a new file of two overlapping Draft arcs, I can snap the intersection and draw a line as I would expect.
Cheers,
Markus
Markus
There are two issues with Draft_Snap_Intersection here:
1.
Endpoints are found:
This is a result of this PR of mine:
https://github.com/FreeCAD/FreeCAD/pull/6780
I did not think this through and this clearly needs more work.
2.
The actual intersection is not found in the provided file:
There is a BoundBox check in the Draft findIntersection function and the two arcs have BoundBoxes that do not intersect:
BoundBox (0, -9.20348, -37.9006, 0, 14.4705, -28.7887)
BoundBox (6e-15, -13.9612, -37.9115, 6e-15, 9.3678, -29.1835)
This check should be removed or a certain tolerance should be added (6e-15 is a floating point rounding error).
1.
2.
Shouldn't that be fixed in Base::BoundBox::intersect() which currently doesn't allow for any tolerance?Roy_043 wrote: ↑Thu Aug 11, 2022 12:53 pm ...
2.
Cheers,
Markus
Markus
You can just enlarge one of the BoundBoxes by a given tolerance.
bb.enlarge(tol)
