What is the possibility to change the planes afterwards?
Batucada
Post by Batucada »
In the previous exercises, it didn't really matter which of the planes you selected. If you now create an object on the wrong plane, what possibility is there to change it later?
Bance
Re: What is the possibility to change the planes afterwards?
Post by Bance »
Which exercises?
It is possible to change the support Property.
Batucada
Post by Batucada »
Bance wrote: Wed Aug 10, 2022 10:28 pm Which exercises?
That's my private exercises :D
Bildschirmfoto 2022-08-11 um 00.45.40.png (56.03 KiB) Viewed 442 times
Where should I go? In none of the possibilities that present themselves I can find a property entry that is in any way related to the term support.
Bance
Post by Bance »
If a sketch has attachment (as they usually do,) it is attached to a support.
Don't you know where the properties are?
Snip macro screenshot-fec7b0.png (38.95 KiB) Viewed 434 times
Batucada
Post by Batucada »
Bance wrote: Wed Aug 10, 2022 10:59 pm Don't you know where the properties are?
This is bothering me.
I forgot the data selection tab.
Thank you very much.
Reorient sketch is perfect for planes and faces - of which we actually don't recommend to use the latter. For a more general approach you can use the AttachmentDialog.
