Merge extrusion with body
scottvan
Post by scottvan »
Hello, this is my first FreeCAD project. I am trying to merge some extrusions with the body, but cannot figure out how. I had made a sketch on the surface of a part and extruded it, but it didn't automatically merge like I thought it would. Will someone point me in the right direction? I've tried searching for an answer and have not come up with one. I have attached the FCStd file. Thank you.
OS: macOS 10.16
Version: 0.20.29177 (Git)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: C/Default (C)
Bat emblem with pins working.FCStd
(140.18 KiB) Downloaded 12 times
Bance
Re: Merge extrusion with body
Post by Bance »
Shalmeneser
Post by Shalmeneser »
Do not mix worbenches if you don't know why.
A solution only with PartDesign :
* I've moved the Path to use the axis.
* I've use a Binder to keep the position of the path.
Bat emblem with pins _SHALM.FCStd
(228.1 KiB) Downloaded 9 times
Capture d’écran 2022-08-11 202226.jpg (27.92 KiB) Viewed 824 times
scottvan
Post by scottvan »
Thank you!
