Split a mold object
Split a mold object
I've created this file to try to create a mold for an object. I want to split it in the middle and save the 2 halves, but I'm having a hard time understanding how to make that happen.. I've looked extensively in the documentation and this forum, but I can't seem to find the solution that works. I can make the split in Part/Cross section, but I can't get it to split and keep the 2 halves. Would appreciate any guidance on how to do this.. Thanks..
- Clamp Mold.FCStd
- (108.28 KiB) Downloaded 20 times
Re: Split a mold object
Create a datum plane, select the part and that plane and use the Part SliceApart tool.
Hi Giterdun, greetings to the Community!
Is this what you are asking?
- Clamp Mold2.FCStd
- (247.8 KiB) Downloaded 12 times
- Clamp Mold2.png (225.73 KiB) Viewed 1006 times
- papyblaise
make Tube less high so that it makes 2 parts of the mold, with the disaggregate tool of Draft (big blue arrow down) get 2 solids
rework it , there is an unmoldable fillet
- moule2.JPG (27.07 KiB) Viewed 928 times
- moule2.FCStd
- (103.21 KiB) Downloaded 11 times
- papyblaise
this is the mold after rework
- moule2.FCStd
- (120.89 KiB) Downloaded 12 times
- Shalmeneser
@papyblaise : Where does you red object come from ?
- Shalmeneser
@Giterdun :
* see PartDesign_Revolution
* see PartDesign_PolarPattern
* see Taper angle (PartDesign_Pad)
* your DatumPlane is useless for what you are showing.
* the ribs shoulb be round at the outside edge
* your sketches are ... awful, you should read chrisb lecture : https://forum.freecadweb.org/memberlist ... ile&u=5646 > see signature
* Sketch004 should not be paddable due to T-junction
* Sketch010 : use Sketcher_ConstrainSymmetric and/or Sketcher_ConstrainEqual
Give your full info (see red banner above).
- Capture d’écran 2022-08-12 120518.jpg (45.58 KiB) Viewed 872 times
- Shalmeneser
- Clamp Mold_SHALMv0.FCStd
- (55.03 KiB) Downloaded 9 times
- Shalmeneser
- Capture d’écran 2022-08-12 131034.jpg (39.57 KiB) Viewed 818 times
- Clamp Mold_SHALM.FCStd
- (56 KiB) Downloaded 10 times
- Where do you expect the parting line plane?
- You should give a draft angle to your part, perpendicular to this plane.
- ClampMold_PartingLine.FCStd
- (110.03 KiB) Downloaded 6 times
- Capture.JPG (25.69 KiB) Viewed 726 times
