I keep receiving an error for "Fusion002". The error appeared after selecting "defeaturing" option on a feature. Now I am no longer able to cut or modify the main part. This is my first time using FreeCAD so I am completely lost. Project attached.
Any help would be greatly appreciated.
Fusion - Input shape is null
- Capture 1.PNG (72.65 KiB) Viewed 591 times
- Combo Module Programming Fixture.FCStd
- (344.15 KiB) Downloaded 9 times
- thomas-neemann
- Shalmeneser
Re: Fusion - Input shape is null
(just a version in PartDesign)
- Combo Module Programming Fixture_SHALM.FCStd
- (103.44 KiB) Downloaded 7 times
- Capture d’écran 2022-08-12 212236.jpg (77.23 KiB) Viewed 525 times
Hi and welcome to the forum!
A recompute fixes the error shown in the tree, But there are more errors, which you see on recompute, e.g. links going out of allowed scope.
I made a test here, which shows that making a union of a Part container doesn't work really well - e.g. you cannot refine it -, you may better use the union on its components instead.
- papyblaise
you make fusions with the Part container, then you make another fusion with a component of the Part container: cube 007, it is not possible
by making more logical fusions and Refine = true , it seems to me that the result is good, and more robust
- base.FCStd
- (231.28 KiB) Downloaded 4 times
