what's going on with shapestring?
Vincent B
Post by Vincent B »
ShapeString doesn't correct display with my freecad.
(font is window's Arial)
OS: Windows 10 Version 2009
Version: 0.21.29936 (Git)
Hash: 3db79c907cd7ef2f75597efdd82ae288ac23ad01
Locale: French/France (fr_
wandererfan
Re: what's going on with shapestring?
Post by wandererfan »
Vincent B wrote: Fri Aug 12, 2022 5:00 pm ShapeString doesn't correct display with my freecad.
The squares represent a glyph that can't be drawn. Does the string have diacritical marks (accent grave, accent circonflexe, etc)?
Roy_043
Post by Roy_043 »
Confirmed.
Note that the ShapeString String property is "Default" in the image. The problem is not caused by the Draft code AFAICT (Draft uses Part.makeWireString to create the wires).
Version: 0.21.30058 (Git)
Hash: cb96332a64db8ae855ca700212eebb0f5151230a
Installed mods:
mario52
Post by mario52 »
Hi
no problem C:/Windows/Fonts/arial.ttf
good also if the size = 0.5 mm and spaces between two characters
Python 3.8.13, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.2
Locale: French/Mars(fr_MA)
mario
Vincent B
Post by Vincent B »
ok with this version ;)
Roy_043
Post by Roy_043 »
So the problem is Python 3.10.5 related?
Syres
Post by Syres »
@looo are you aware that the Python 3.10.x Windows Conda build produces the error raised by the OP but the Python 3.8.x equivalent on the same box with the same font is fine?
looo
Post by looo »
Syres wrote: Sun Aug 14, 2022 11:05 pm @looo are you aware that the Python 3.10.x Windows Conda build produces the error raised by the OP but the Python 3.8.x equivalent on the same box with the same font is fine?
only windows? or is it a general py3.10 issue?
Roy_043
Post by Roy_043 »
FYI another post reporting the same bug:
https://forum.freecadweb.org/viewtopic.php?f=23&t=71383
Syres
Post by Syres »
looo wrote: Wed Aug 17, 2022 4:06 pm only windows? or is it a general py3.10 issue?
I eventually got round to downloading and adding the Arial font to my Linux Mint 20.3 partition and tested with your latest AppImage and it works fine so looking like a Windows only with Python 3.10.x issue to me. I noticed py 3.10.6 only appeared on conda forge literally 2 days ago so I'll attempt to build an environment on my miniconda locally and see if it's any different.
