Filleting Problems
RussG
Filleting Problems
Post by RussG »
OS: macOS 10.16
Version: 0.20.29177 (Git)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: C/Default (C)
Installed mods:
  * fasteners 0.3.50
I'm making something of a box. Beginning with a sketch that is sort of U shaped sketch that I padded I then made some sketches I padded to form caps to place on the ends of the box. I have been trying to fillet the insides of the box where the long body of the box meets the end caps. The first screenshot shows that I can make the fillets, but the other screenshots that zoom in closer reveal the problems in greater detail.
The screenshots show that at the top rear of the box there are problems with the fillet. Changing the size of the fillet changes the problem. With the fillet set to 1 mm a little shelf of material appears above the box. With the fillet set to 1.5mm a little mountain appears. These things only seem to occur at the rear corner. Plus, at the rear corner the fillet turns toward the outside of the box instead of the inside of the box, The direction of the fillet at the front corner is what I'm looking for. Perhaps due to the angles of the parts?
I don't know if I need to model the box some other way, or fillet it some other way. I do need those internal corners rounded, however. I rounded them on the long dimension within the sketch but at the ends of the of I have two parts meeting so I'm trying to fillet between two parts, not simply along the edge of one part. Is there a way I can accomplish this?
Thanks.
Failed Fillet.FCStd
(42.71 KiB) Downloaded 8 times
Fillet Pullled Back View.png (83.89 KiB) Viewed 622 times
Fillet, Top View.jpg (47.1 KiB) Viewed 622 times
Fillet 1mm.jpg (28.5 KiB) Viewed 622 times
Fillet 1.5mm.jpg (44.01 KiB) Viewed 622 times
user1234
Re: Filleting Problems
Post by user1234 »
RussG wrote: Fri Aug 12, 2022 5:33 pm I don't know if I need to model the box some other way, or fillet it some other way.
Just refine the model before filleting, then all is neat.
Greetings
user1234
Shalmeneser
Post by Shalmeneser »
Pad001 : Refine = true
You should not sketch upon face : TNP
You should avoid blank zone in your pictures : I was waiting them to end downloading :lol: :evil:
RussG
Post by RussG »
user1234 wrote: Fri Aug 12, 2022 5:40 pm
Greetings
user1234
Awesome! Easy fix! Thanks!!!
user1234
Post by user1234 »
RussG wrote: Fri Aug 12, 2022 6:04 pmEasy fix!
No fix, just the way it works.
Greetings
user1234
RussG
Post by RussG »
user1234 wrote: Fri Aug 12, 2022 6:10 pm
Greetings
user1234
How is one supposed to know when to refine? Is it something to do regularly or just one unexpected problem occur?
user1234
Post by user1234 »
RussG wrote: Fri Aug 12, 2022 6:15 pm How is one supposed to know when to refine? Is it something to do regularly or just one unexpected problem occur?
It has very good constructive and technical reasons, but i do not have time now, i write it later.
Greetings
user1234
Shalmeneser
Before refine (when the adjacent coplanar faces are fused), the corner counts 5 edges.
After refine, a useless seam dissapears ant the filet can work.
Capture d’écran 2022-08-12 202820.jpg (10.65 KiB) Viewed 542 times
Capture d’écran 2022-08-12 202952.jpg (8.44 KiB) Viewed 542 times
RussG
Post by RussG »
Shalmeneser wrote: Fri Aug 12, 2022 5:44 pm Pad001 : Refine = true
I'm not sure what that means.
Shalmeneser wrote: Fri Aug 12, 2022 5:44 pm You should avoid blank zone in your pictures : I was waiting them to end downloading :lol: :evil:
10.4. I'm working on a system where I don't have access to a photo editor with which I'm familiar and I haven't figured out how to crop with the software I'm using. I will look again for that because I'd prefer not to send images with blank space. Sorry to make you wait an extra 1/10 second for the extra download time :)
RussG
Post by RussG »
Shalmeneser wrote: Fri Aug 12, 2022 6:31 pm Before refine (when the adjacent coplanar faces are fused), the corner counts 5 edges.
By any chance are you (or anybody else for that matter) aware of a discussion anywhere on using "refine". A quick search on YouTube turned up a few things which I will look at, but if there is a written disillusion somewhere I'd be interested to see it. Thanks.
