Part Design workbench and Gear
NHSA_Rainer
Post by NHSA_Rainer »
When I make a gear it always sits on the XY plane.
How can I change its orientation and put it on the XZ or the YZ plane ?
Thanks Rainer
Robot_v2.FCStd
(143.6 KiB) Downloaded 24 times
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Locale: Spanish/Latin America (es_419)
Installed mods:
  * AnimationFreeCAD 1.0.0
  * fcgear 1.81.0
  * Help 1.0.3
  * ThreadProfile 1.81.0
papyblaise
Re: Part Design workbench and Gear
Post by papyblaise »
change "placement >Axes
thomas-neemann
Post by thomas-neemann »
NHSA_Rainer wrote: Sat Aug 13, 2022 4:21 pm ...
I would do it with transformation 90 degrees
drmacro
Post by drmacro »
One of these should suffice:
Properties, change the rotation.
Right click on it in the tree, select Translate.
Select desired plane, click Map sketch Image
Syres
Post by Syres »
What would be nice is to have the similar functionality as Fasteners where you can select the edge of a hole or shaft before clicking the fastener required and it be created at the location and in the same plane. I've had a look at the code of both and it's definitely transferable but whether it's within my capabilities we'll see in the next day or two.
NHSA_Rainer
Hi and thanks,
Maybe I did not express myself correctly. Repositioning of the gear is possible while I am in the Timing gear. In the moment I drag the gear into body and add a sketch it goes back to the XY plane ...
I can manipulate the gear while it is in the XY plane which means I can add holes to the gear etc. but not when it is in another placement as XY plane. FreeCAD reports me there is no solid from to substract anything.
papyblaise
Question that lacks precision > stupid answer, it's not my fault
you orient the Body before making the basefeature
gear2.FCStd
(205.23 KiB) Downloaded 17 times
Syres
Post by Syres »
NHSA_Rainer wrote: Sat Aug 13, 2022 8:01 pm Maybe I did not express myself correctly. Repositioning of the gear is possible while I am in the Timing gear. In the moment I drag the gear into body and add a sketch it goes back to the XY plane ...
Purely from a workflow point of view I would create the shafts for the gears to reside first and then using the modified files attached you can select the edges of the shaft (only one Body in Part Design but multiple shafts if they are in Part/Draft) and it will create the gears in their orientation at the end of the shaft(s).
With FreeCAD closed, copy the _functions.py into C:\Users\username\AppData\Roaming\FreeCAD\Mod\fcgear\pygears folder and copy commands.py into C:\Users\username\AppData\Roaming\FreeCAD\Mod\fcgear\freecad\gears folder.
If you think it's worthwhile submitting the change to the author, let me know.
Tested using:
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.20.1.29410 (Git)
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Installed mods:
  * A2plus 0.4.56a
  * Assembly3 0.11.3
  * CfdOF 1.17.7
  * Curves 0.5.4
  * fasteners 0.3.51
  * fcgear 1.0.0
  * freecad.xray 2022.4.17
  * Manipulator 1.4.9
  * Plot 2022.4.17
  * sheetmetal 0.2.56
  * Silk 1.0.0
Edit: Added function for PD helper sketches
_functions.py
(10.81 KiB) Downloaded 12 times
commands.py
(7.15 KiB) Downloaded 14 times
NHSA_Rainer
papyblaise wrote: Sun Aug 14, 2022 8:24 am Question that lacks precision > stupid answer, it's not my fault
Hi papyblaise,
Sorry ... :oops:
NHSA_Rainer
Hi and thanks,
I analyzed thoroughly your example sketch and saw that I have to set the angle of the BOdy to Y=1 and Angle to 90°.
Thanks from a Dummy ...
Rainer
PD the funny thing now is that the XY plane for me being always the main plane when I start my projects is now vertical for drawing new stuff and so the other axis too and that is truly irritating after I have got used to the normal orientation of the coordinate system.
Well I stop complaining for a good program which at the end is Free of Charge and has made me design a lot of stuff which works. Thanks to all developping this good software package ;)
