A tough nut for the solver
drmacro
Re: A tough nut for the solver
Post by drmacro »
Batucada wrote: Sun Aug 14, 2022 5:06 pm
drmacro wrote: Sun Aug 14, 2022 3:15 pm All I did was open the sketch and select edges and attempt to move them. And, they moved, thus the vertexes were not marked coincident.
After all, I'm always looking for an excuse for not seeing it.
I will do the wobble test soon, I promise....
But if you are concentrated on not making a mistake, then you are also rock-solidly convinced at the end that you really haven't made a mistake. The problem is obviously that the coincidences are not displayed. It would be nice if there were an inspection function, you select an element and then you get the constraints that belong to that element. Well, Christmas is coming soon, so maybe we can make a wish.
As I said, the inspection function is Sketch>Validate sketch.
You can avoid nearly all missing coincidents by using the polyline tool, trim tool, etc. They automagically make the vertexes coincident.
The other thing is to completely sketch and check/fix coincidents before using any dimensional constraints.
Using these techniques I have not created a missing coincident in a very long time. :mrgreen:
Batucada
Post by Batucada »
Bance wrote: Sun Aug 14, 2022 5:09 pm Image
No need to wait......
Sketcher_SelectConstraints
It's really nice to point out such a tool to me. It was an occasion to finally have a look at the tools in the Sketcher toolbar. I think now it would make sense to book an introductory course again. At the beginning, like probably many other users, I had neither eyes nor ears for these many details.
drmacro
Post by drmacro »
Batucada wrote: Sun Aug 14, 2022 5:37 pm
@chrisb has graciously provided the Sketcher Lecture...70+ pages detailing the Sketcher...time for some light reading? ;)
Batucada
Post by Batucada »
yes, I have read @chrisb's Sketcher tutorial, but in German, probably I should follow his hint and have a look at the English version.
Shalmeneser
Post by Shalmeneser »
1) the 1st rule is to keep all vertexes upon each other.
2) Tangency (via Polyline)
3) Vertical / horizontal
It's possible here to shake the sketch (moving random line) to verifiy the coincidence.
4) other geometric constraints (point on object, parallelism, equality)
shake again
5) dimensions
[Trim tool need to be checked each time because it usually kills coincidence.]
Turbine_Isolierteil2_SHALM.FCStd
(6.81 KiB) Downloaded 2 times
drmacro
Post by drmacro »
Shalmeneser wrote: Sun Aug 14, 2022 7:27 pm ...
That has never happened to me in hundreds of sketches and hundreds of trims... :roll:
