A tough nut for the solver
Here is a simple sketch that probably presents the solver with a problem. The sketch contains:
8 horizontal lines
6 vertical lines
4 arcs of 90
Constraints are present
4 length measures
1 radius
1 symmetry
12 coincidence
8 tangential connections to the circular arcs
various equality constraints
From a purely mathematical point of view, the solver should be able to find no more degrees of freedom. But it does not. It quits its job with 6 degrees of freedom. At first I thought that the number of coincidences was too low, but that is already appropriate.
. Have fun solving it, I'll keep looking anyway.
The sketch was created while I was looking for a solution to another problem. The final sketch looks a little different, but the problem presented here does not appear in the final sketch, but another one does, which is similarly strange.
8 horizontal lines
6 vertical lines
4 arcs of 90
4 length measures
1 radius
1 symmetry
12 coincidence
Re: A tough nut for the solver
I see them immediately...
- papyblaise
voilà
- Turbine_Isolierteil3.FCStd
- (22.65 KiB) Downloaded 8 times
What amuses me is that there's almost always at least twice as much geometry in these problem sketches than is necessary...
- Turbine_IsolierteilBance.FCStd
- (6.52 KiB) Downloaded 8 times
For a solution I had to delete some equality constrains. After that I added the 4 coincident constrains. The last thing I did was completing the constrains. The original problem is the equality constrains
I hope that one day I will get the view for it. And it reassures me, I'm apparently not a hopeless talent. But it still took me some time to get behind the method to the solution. Part of the problem is that the missing coincidence is not immediately visible.
Of course, it is tempting to take the ready-made solution. But that was not what mattered to me. I studied your solution versus my approach and saw the differences. Part of my learning process was to be a little more careful in the future in the use of equality constraints. That was one aspect. The second aspect of coincidence requires knowing how to temporarily disable certain constraints everything else at @drmacro. Merci beaucoup.
I hope I have been able to brighten your day a little.
That was now a French-Dutch joint effort. Your words plus the French solution have brought me back to the path of virtue.
I hope I can return the help to the forum one day.
I never use autoconstraints. Relying on auto instead of manual often leads to this sort of problem. One thinks that a connection has been made, but it really wasn't.
When using manual-only I know that I need to check every connection. The only reliable use of autoconstraint is for polyline.
I realize others will disagree with this. Fine, just another view.
Gene
Gene
All I did was open the sketch and select edges and attempt to move them. And, they moved, thus the vertexes were not marked coincident.Batucada wrote: ↑Sun Aug 14, 2022 2:25 pmI hope that one day I will get the view for it. And it reassures me, I'm apparently not a hopeless talent. But it still took me some time to get behind the method to the solution. Part of the problem is that the missing coincidence is not immediately visible.
Here I've used Sketcher validate to find them.
If, as sometimes is the case, wiggling lines won't move the lines, you can go to the constraints panel a deactivate one or two constraints to allow movement.
Hmm...speaking of wiggle, there is a macro available in Addon manager called Shake Sketch for this purpose as well.
After all, I'm always looking for an excuse for not seeing it.
I will do the wobble test soon, I promise....
But if you are concentrated on not making a mistake, then you are also rock-solidly convinced at the end that you really haven't made a mistake. The problem is obviously that the coincidences are not displayed. It would be nice if there were an inspection function, you select an element and then you get the constraints that belong to that element. Well, Christmas is coming soon, so maybe we can make a wish.
EDIT:
I just used the Validate Sketch tool on the file that was uploaded for the starter post. Well, I learned something again. The tool is not only able to find missing coincidences, but also to add them. I think this tool is worth a special note.
