Need help on cuting holes in spiral line for one circle...
I created two cubes and then in Draft select Polar array with 180 angle and Interval Axis X -0,2 to get it but it is not ok..
I test it with real spiral line and see that holes doesnt go like it shoud...see image
How to create this holes on real spiral?
Thank you
- spiral holes.jpg (87.93 KiB) Viewed 599 times
- Shalmeneser
Re: holes in spiral line
ok i try, but dont know how to rotate cubes to face the line?
sorry I am not expert, just using freecad time to time
thank you
thank you
- rotate cubes.jpg (90.26 KiB) Viewed 572 times
Look at the documentation linked above and the Alignment section.
it seems that the supported plane for referencing cubes is not perpendicular to spiral axis, it creates a obal efect on cubes pattern
yes, i find quick solution to change Y axis of cube...
- fix cube in spiral.jpg (112.69 KiB) Viewed 453 times
- Shalmeneser
You should provide your file each time.
