Having trouble using RENDER WB with Blender
gbgb
Post by gbgb »
I am trying to use the RENDER WB and since I already have Blender installed decided to use it as the rendering program.
This is what I did:
In the preferences-render screen I placed to the blender.exe path (I see that there is an automatic parameter: --samples 100).
Opened an existing file
Opened the Render WB
Added a cycles rendering project to the part
Selected the body in the part and added it as a rendering view
Selected the project and pressed "render"
Looks like it invokes blender but no rendering is performed and I get the following:
14:31:45  Starting rendering...
C:/Program Files/Blender Foundation/Blender 3.1/blender.exe --samples 100 --output C:/Users/xxxxx/AppData/Local/Temp/FreeCAD/Cache/FreeCAD_Doc_8715008f-5e28-4e3a-98aa-b94787b62fc3_642215_15564/Projectmqizw9bh.png --width 800 --height 600 "C:/Users/xxxxx/AppData/Local/Temp/FreeCAD/Cache/FreeCAD_Doc_8715008f-5e28-4e3a-98aa-b94787b62fc3_642215_15564/Projectmqizw9bh.xml"
14:31:46  unknown argument, loading as file: --samples
14:31:46  Read prefs: C:\Users\xxxxx\AppData\Roaming\Blender Foundation\Blender\3.1\config\userpref.blend
14:31:46  Error: Cannot read file 'C:\Program Files\FreeCAD 0.20\bin\--samples': No such file or directory
14:31:47  Error: argument has no '.blend' file extension, not using as new file, exiting! C:\Program Files\FreeCAD 0.20\bin\--samples
14:31:47  Saved session recovery to 'C:\Users\xxxxx\AppData\Local\Temp\quit.blend'
14:31:47
14:31:47  Blender quit
14:31:47  Exiting rendering - Return code: 1
Reason: Put error in bbcode code tags
drmacro
Re: Having trouble using RENDER WB with Blender
Post by drmacro »
Hmm...no idea what the problem might be.
I have had way better luck using Sverchok nodes in Blender to just read the FreeCAD file directly and then use Blender...
Post by Kunda1 »
CC @howetuft (RenderWB dev)
FYI, if howetuft doesn't respond here, then open a ticket on the Render Workbench issue queue: https://github.com/FreeCAD/FreeCAD-rend ... dated-desc
Syres
Post by Syres »
gbgb wrote: Mon Aug 15, 2022 11:45 am
I'm not sure where you've read (unless something major has changed recently and the README hasn't been updated) that the user can just point the Wb at Blender, I've always understood the user has to point to a standalone compiled version of Cycles. See https://forum.freecadweb.org/viewtopic.php?t=48599 for more info.
gbgb
Post by gbgb »
Syres wrote: Mon Aug 15, 2022 4:13 pm
My misunderstanding - I thought that since it is integrated into blender then this is where I should point. Thanks
howetuft
Post by howetuft »
Yes, @Syres is right: Render WB works with Cycles (standalone), not with Blender.
@gbgb you have to choose among the supported rendering engines, including Luxcore, OspRay, Cycles (standalone), pbrt, Appleseed, pov-ray - but not Blender... Good luck!
gbgb
Post by gbgb »
howetuft wrote: Mon Aug 15, 2022 5:16 pm @gbgb you have to choose among the supported rendering engines, including Luxcore, OspRay, Cycles (standalone), pbrt, Appleseed, pov-ray - but not Blender... Good luck!
Can someone suggest which would be the easiest to install and use on a Windows system? Not looking for too many features, just basic rendering for mechanical objects.
Edit: My PC has only the internal Intel graphic processor, if it matters.
howetuft
Post by howetuft »
My suggestion would be Luxcore: it's powerful, well packaged and works out-of-the-box.
gbgb
Post by gbgb »
Thanks.
Will give it a try
drmacro
Post by drmacro »
Nothing against the Render workbench. I spent more than a day messing around trying to add renderers on my system and gave up. The reason I was so glad to find Sverchok nodes in Blender could read (and write) FreeCAD files directly was I didn't need to deal with installing render engines that were already functional in Blender.
Once the file is in Blender all the tools of Blender are available. Backgrounds, ray tracing, animation, even making fillets that FreeCAD can't handle.
