Hi all
I finally have time to just playi around with Freecad. I'm drawing a simple box with a lid using spreadsheets and shape binders. The first question is my drawing methodology. I'm trying to; 1, new part ( lid~) new "body" however if for example, I place screw "studs" in each corner I end up with 4 x bodies, do I need a separate body for each screw "stud" ( round post into which a screw will go in each corner of the box).
2, Im re-naming each body as I draw it
3, is the use of "datum" planes helpful? when placing these "separate" bodies or holes on faces
2nd question; when using "Thicknesses" , drawing a box add a thickness 5mm , however, the "base" needs to be 10mm as there is a pocket in it. Is there a way to define a different thickness to the base different to the walls?
All advice gratefully received ...
Stephen
OS: Ubuntu 21.10 (KDE)
Installed mods:
* Estimate 0.1.2
* sheetmetal 0.2.55
* A2plus 0.4.56a
* MOOC 2022.4.21
and my laptop ( no laughing now! Shes an oldie but a goodie ! ( hahaha) its still chugging along!
Operating System: Ubuntu Studio 21.10
KDE Plasma Version: 5.22.5
KDE Frameworks Version: 5.86.0
Qt Version: 5.15.2
Kernel Version: 5.13.0-52-lowlatency (64-bit)
Graphics Platform: X11
Processors: 4 × Intel® Core™ i3-3217U CPU @ 1.80GHz
Memory: 3.7 GiB of RAM
Graphics Processor: Mesa DRI Intel® HD Graphics 4000
Thickness question and general help
- survival box.FCStd
- (171.42 KiB) Downloaded 14 times
Re: Thickness question and general help
You don't need the Part object, here. You need them if your model has several of them and in each are several bodies, and each of these Part containers should be handled as a unit, e.g. for moving all bodies together.
Such studs should go into the body where they belong to (unless you machine the box, and the studs are in fact small separate tubes.however if for example, I place screw "studs" in each corner I end up with 4 x bodies, do I need a separate body for each screw "stud" ( round post into which a screw will go in each corner of the box).
Good idea!2, Im re-naming each body as I draw it
DatumPlanes are helpful, if you have several sketches to be drawn on them. Otherwise it is often better to attach the sketches directly to what you intended the DatumPlane to be attached to.3, is the use of "datum" planes helpful? when placing these "separate" bodies or holes on faces
No, thickness cannot do that. I'm very hesitant to tell you an easy workaround, because it will make your model prone to break due to the topological naming problem.2nd question; when using "Thicknesses" , drawing a box add a thickness 5mm , however, the "base" needs to be 10mm as there is a pocket in it. Is there a way to define a different thickness to the base different to the walls?
You can, if you really want to, apply thickness and then select a face you want to be different and make directly a pad or pocket.
I don't recommend at your current level of knowledge to mix Part and PartDesign functions. Stay in PartDesign until you reach its limits and then use Part functions.
- papyblaise
to have thicker material around the hole, just add the thickness of the walls of the hole on the bottom,
a few days ago we already had the question to have a bottom of variable thickness, the answer is; Nope
- fond épais.FCStd
- (28.79 KiB) Downloaded 6 times
- fond épais.JPG (28.4 KiB) Viewed 440 times
Thank you all for the replies
With the cost of 3d printers becoming cheaper. It has allowed me to print rather than "make" things out of steel. For example, I needed a speedometer bracket to pass a local vehicle check,, Draw print done ! So Im finding that Im drawing more and more. Before it was a 2d cad and off to the local machine shop, then a long sit down after hearing the price! ,,
Freecad has become very useable for me. So I thank you all for the efforts and replies.
and I still find it amazing that Freecad words on this old machine ,, not a problem !
Kind Regards stephen
