Can't make a union of two bodies
hph
Post by hph »
I'm trying to make a union of the "Main Body" and "Support" bodies here. Eventually I want to add fillets between the two. I get this error:
12:04:40  <Exception> MultiFusion failed
12:04:40  Recompute failed! Please check report view.
My project is attached. Any help would be appreciated. :)
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Remember to thank the struggle-bus driver :ugeek:
Re: Can't make a union of two bodies
Hi and welcome to the forum!
hph wrote: Mon Aug 15, 2022 4:14 pm My project is attached.
No.
Fusion sometimes fail if you have coplanar faces or seams on seams. If possible allow them to overlap a little bit.
hph
Post by hph »
Hmm I hit the attach button and it uploaded, let me try again here.
Though I believe that is the problem.
Thanks chris :)
turntable, top 3.FCStd
(62.97 KiB) Downloaded 7 times
thomas-neemann
Post by thomas-neemann »
hph wrote: Mon Aug 15, 2022 6:17 pm ...
in realthunder i get this error message
hph
Post by hph »
thomas, thanks, looks like the problem was having exactly coplanar faces.
Though now I have this problem where my thru holes are intersected by the other body's geometry. I've tried every option (Through all, Dimension, etc.); IDK why they are not working.
(Design has been changed to a rotated cross section of the supports, instead of discrete supports.)
EDIT: I could just change the support sketch, but I feel I would run into this again later.
(82.93 KiB) Downloaded 3 times
thomas-neemann
hph wrote: Mon Aug 15, 2022 6:38 pm ...
now I have 2 error messages
hph
Post by hph »
hmm
thomas-neemann
hph wrote: Mon Aug 15, 2022 6:54 pmhmm
if you want i can build it in part and link a video of it here
hph
Post by hph »
I think I'm good for now, thanks :)
Do you know how to change the scale of a view in a drawing? I adjust the scale in properties and it does nothing.
Bance
Post by Bance »
Really for PD WB this is incorrect workflow.
If it is a single solid it should be modeled in the same body.
Something like this....
turntable, top 3Bance.FCStd
(242.14 KiB) Downloaded 2 times
