Sketching by importing coordinates
Debasish19
Post by Debasish19 »
FreeCAD version -
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Problem Statement [A rough description of what I want to design using the FreeCAD] -
Consider an irregular cylindrical tube. I have the tube length and the x-y coordinates of the start and end cross-sections [assume ten coordinates for each cross-section in a txt file]. I am struggling with how to build these kinds of models with FreeCAD. Or it's not possible at all.
I have an idea of what I should be doing, but I am not sure how to do it-
Create a body -> Start a sketch -> Select a plane -> Import coordinates to connect and create the first cross-sectional plane -> Create a second sketch and follow the same to create the second cross-sectional plane. Then use the "loft" option to connect both sketches.
But I am not sure how to import coordinates to sketch. Could you please help me or provide some ideas to solve this problem.
Experience with FreeCAD -
I am new to FreeCAD and building CAD models. This is my first post here. I am sorry if I am breaking any forum rules here.
NewJoker
Re: Sketching by importing coordinates
Post by NewJoker »
Try using Draft Point - you can specify coordinates manually or with Python scripting. Then you could convert these points to sketches for further operations but keep in mind that sketches have to be planar - all points for a single sketch must lie in the same plane. But maybe conversion to sketches won’t be necessary.
edwilliams16
Post by edwilliams16 »
Make Wires from your imported points, then use Part.Loft in the Gui (or script it) to loft them together
from math import sin, cos, pi
import Draft, Part
V3 = App.Vector
doc = App.ActiveDocument
npts = 20
thetas = [i * 2 * pi/npts for i in range(npts)]
r1 = 10
circle1 = [r1 * V3(cos(theta), sin(theta), 0) for theta in thetas]
wire1 = Draft.makeWire(circle1, closed = True)
r2 = 20
circle2 = [r2 * V3(cos(theta), sin(theta), 1) for theta in thetas]
wire2 = Draft.makeWire(circle2, closed = True)
doc.recompute()
Above I synthesized the points. You'll need to read them in from your file. The Points workbench might be useful in this regard.
edwilliams16
If you want a smooth fit through your imported points, you can use a Draft BSpline instead
import Draft, Part
V3 = App.Vector
npts = 20
r1 = 10
#wire1 = Draft.makeWire(circle1, closed = True)
bs1 = Draft.makeBSpline(circle1)
r2 = 20
#wire2 = Draft.makeWire(circle2, closed = True)
bs2 = Draft.makeBSpline(circle2, closed = True)
doc.recompute()
Debasish19
Thanks @edwilliams16 and @NewJoker for answering my question and sharing the code. I will give it a try and let you know.
kohnagha
Post by kohnagha »
--> Import your coordinates into Points-WB.
--> Convert pointClouds to BSplines with "Aproximate"-Tool in Curves-WB. Adjust Splines in General-Section of Spline-Data-Tab (close spline, ...).
--> Make a Loft in Part-WB (look that Start/EndPoints of Start/EndSplines are nearby to avoid twisting).
