Why subtractive objects helix not showing up ? [Solved]
FredCailloux
Post by FredCailloux »
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Locale: French/Canada (fr_CA)
A body is created with 2 additive objects and 3 subtractive objects, in that order.
The two first objects are appearing as expected.
When the third object, a subtractive groove is added it seems to work fine.
When the fourth attribute, a subtractive pocket is added it seems to work fine.
When the fifth attribute, a subtractive helix is added, it does not appear but no error is generated.
I struggle to find out why the subtractive helix does not appear, and how to correct the problem.
No error is generated nor any kind of message to that effect.
Can someone pls take a look at this MF_SpotCover.FCStd file ? Thanks
MF_SpotCover.FCStd
(333.65 KiB) Downloaded 7 times
Great results only comes with great understanding. Great memory is just an illusion.
Re: Why subtractive objects helix not showing up ?
sktThreadNut must not go up to the y-axis. Thius leads to self intersections, which are not allowed. Cut the center with an appropriate cylinder.
FredCailloux
chrisb wrote: Mon Aug 15, 2022 10:00 pm sktThreadNut must not go up to the y-axis. Thus leads to self intersections, which are not allowed. Cut the center with an appropriate cylinder.
Answer similar to a previous question of mine, which was properly answered. I should have thought about it, damn ! :oops:
Thanks, I sure wont forget that one.
Shalmeneser
Post by Shalmeneser »
The cutting form should be as small as possible because helix is very heavy in computation and file.
So you need a simple pocket before the subtractive helix.
