How to edit the author name and other data in a TechDraw view?
Binarus
Post by Binarus »
Dear all,
FreeCAD newbie here ...
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
I have successfully created a TechDraw view. Now I would like to change the author name, drawing title and so on. I guess I would be able to do that by altering the template, but I believe that this is not the intended method.
I have found this post where a solution to the problem is presented. However, that solution is from 2017 and does not work with my version. Notably, nothing happens when I click on the ellipsis at the end of the property values of the "Editable Texts" entry.
The template I am using is
A3_Landscape_ISO7200TD.svg
from the TechDraw folder.
The attached screenshot shows the situation.
Put shortly, what exactly (step by step) do I need to do to edit the author name, drawing title and the other metadata?
Thank you very much in advance, and best regards,
Binarus
Bance
Re: How to edit the author name and other data in a TechDraw view?
Post by Bance »
Click on the green dot in the page view....
wandererfan
Post by wandererfan »
Binarus wrote: Tue Aug 16, 2022 4:50 pm Notably, nothing happens when I click on the ellipsis at the end of the property values of the "Editable Texts" entry.
Yes, the PropertyEditor can not edit PropertyMap yet.
Binarus wrote: Put shortly, what exactly (step by step) do I need to do to edit the author name, drawing title and the other metadata?
Click on the green square and a dialog box will open. Enter the new text and click OK/
Binarus
Post by Binarus »
@Bance @wandererfan
And I was wondering all the time why a part of those fields' labels is green ... Now I am really embarrassed.
Thank you very much for your fast support!
