PathArray misplaced
Vincent B
PathArray misplaced
Post by Vincent B »
With the array is not on the edge? :roll:
OS: Windows 10 Version 2009
Version: 0.21.30058 (Git)
Hash: cb96332a64db8ae855ca700212eebb0f5151230a
Python 3.8.13, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.2
Locale: French/France (fr_FR)
PathArray_misedplaced.FCStd
(10.29 KiB) Downloaded 12 times
Roy_043
Re: PathArray misplaced
Post by Roy_043 »
AFAICT the array is correct. The problem is caused by the Ruled_Surface001 object. Its geometry is at a distance from the origin of the coordinate system define by its Placement.
Vincent B
Post by Vincent B »
PathArray give + (x,y,z) offset with (x,y,z) origin of the object. :roll:
Something wrong.
test2.FCStd
(11.61 KiB) Downloaded 7 times
Roy_043
Post by Roy_043 »
Same issue: the command does not care how the object to be arrayed is positioned relative to the path.
RTM: Draft_PathArray#Alignment
Vincent B
Post by Vincent B »
Roy_043 wrote: Wed Aug 17, 2022 6:40 pm Same issue: the command does not care how the object to be arrayed is positioned relative to the path.
it should! how to do if the part is not on (0,0,0)? :roll:
the extra placement is not very useful for an easy use.
and then, the align mode is not usable.
UsingPlacement.FCStd
(11.17 KiB) Downloaded 5 times
Roy_043
Post by Roy_043 »
Vincent B wrote: Thu Aug 18, 2022 5:44 pm how to do if the part is not on (0,0,0)?
Create a different object or put it in a Std_Part.
Using_Std_Part.FCStd
(9.27 KiB) Downloaded 6 times
Vincent B
Post by Vincent B »
it's not working :D u gave an offset to the sketch.
Vincent B
Post by Vincent B »
Another thing: binormal align mode for the PathArray is missing. :roll:
Roy_043
Post by Roy_043 »
Not sure why you insert the rolling eyes emoji here. seems OT and a FR.
