[SOLVED] poor frame rate if I use displaylink dock and external screens
schafatz
Post by schafatz »
Hi everyone,
I use FreeCAD 0.19.3 (FreeCAD_0.19.3-Linux-Conda_glibc2.12-x86_64.AppImage) on a Laptop (Ryzen 7 4800 H , 16GB Ram) and run an Ubuntu 20.04 off the shelve.
This works flawlessly. 3D objects are being rendered as I'd expect at a sustainable frame rate of at least 40FPS. Same when I connect an external display directly to the machine via HDMI.
As soon as I connect the Laptop to a displaylink dock via USB C the frame rate drops (0.1-5FPS) and FC becomes de facto inoperable. Enabling software OpenGL hasn't had any positive effect.
Anybody facing the same issues? Does anybody have a hint where to start my investigation to sort out the problem?
Configuration? Drivers? ... I'm a bit puzzled.
Thanks!
thomas-neemann
Re: poor frame rate if I use displaylink dock and external screens
Post by thomas-neemann »
schafatz wrote: Wed Aug 17, 2022 10:40 am ...
do you have nvida graphics hardware?
schafatz wrote: Wed Aug 17, 2022 10:40 am Enabling software OpenGL hasn't had any positive effect.
Please note that you need to restart FreeCAD to see an effect after changing that setting.
Syres
Post by Syres »
If you do the simplest form of research you'll see that Displaylink is specifically designed for applications that are mainly static such as email, spreadsheets etc not gaming, 3D apps so your feedback is exactly what is expected.
thomas-neemann
Syres wrote: Wed Aug 17, 2022 3:10 pm ...
thanks for this good information
schafatz
Post by schafatz »
thomas-neemann wrote: Wed Aug 17, 2022 1:22 pm
No, I use the Ryzen's GPU. Don't know anything more about the underlying technology, sorry.
schafatz
Post by schafatz »
Syres wrote: Wed Aug 17, 2022 3:10 pm If you do the simplest form of research you'll see that Displaylink is specifically designed for applications that are mainly static such as email, spreadsheets etc not gaming, 3D apps so your feedback is exactly what is expected.
Hi Syres!
I don't agree but would you please share your source of knowledge, for my personal interest? Thanks!
E.g. the Googleearth webversion works perfect with my Displaylink setup.
But the most important: I found a working solution solving my issue!
Choosing the Wayland-mode at login instead of X11-mode makes FreeCAD and Googleearth pro for Ubuntu work like charm!
user1234
Post by user1234 »
schafatz wrote: Thu Aug 18, 2022 9:30 am E.g. the Googleearth webversion works perfect with my Displaylink setup.
I am not an expert in graphic card usage, but just saying, that a webversion is not the same as a graphiccard calculated output, FreeCAD is no someone else computer (a. k. a. "Cloud") program.
schafatz wrote: Thu Aug 18, 2022 9:30 am Choosing the Wayland-mode at login instead of X11-mode makes FreeCAD and Googleearth pro for Ubuntu work like charm!
Maybe wayland can bypass the output. Anyway, as long it works.
Greetings
user1234
