[Solved] Fastener WB gives 'Type must be "Shape", not NoneType' error when importing nut
PAS_Drafter
Post by PAS_Drafter »
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
  * Assembly4 0.12.3
  * Curves 0.5.4
  * ExplodedAssembly
  * fasteners 0.3.51
  * Manipulator 1.4.9
  * MOOC 2022.4.21
  * OpticsWorkbench 1.0.8
  * sheetmetal 0.2.56
  * ToolViewReverse_ToolBar
Hi, I just tried to use the Fasteners WB to bring in some nuts on a drawing, and it gave me the following error "Type must be "Shape", not NoneType". Did a quick search on it and didn't find anything. Anyone have any ideas what I might all of the sudden be doing wrong? It has worked well in the past.
On a side note, it would be nice if that error messages stayed on the screen longer when you move the cursor over the part to see the error. It only stays on my screen for a second or two and I often have to do it 4 or 5 times to read the message.
FastenersError.FCStd
(9.87 KiB) Downloaded 8 times
heron
Re: Fastener WB gives 'Type must be "Shape", not NoneType' error when importing nut
Post by heron »
Hello, you have outdated your fastener workbench.
Update it with Addon Manager.
Shalmeneser
Post by Shalmeneser »
Suppress the body ! Don't know what is the problem.
Here a recompute does the trick out of the box. So an update should indeed do the trick. 0.3.51 is my version:
OS: macOS 10.16
Version: 0.21.29997 (Git)
Hash: b52967d52ac46eff7c59e74d991f3f5b298944ef
Locale: C/Default (C)
Installed mods:
  * FC_SU
  * FeedsAndSpeeds 0.4.0
  * fcgear 1.0.0
  * fasteners 0.3.51
  * sheetmetal 0.2.56
  * ExplodedAssembly
  * Curves 0.5.4
PAS_Drafter
chrisb wrote: Wed Aug 17, 2022 6:15 pm Here a recompute does the trick out of the box. So an update should indeed do the trick. 0.3.51 is my version:
Updating the Fastener Workbench did fix the problem.
However, that was the first thing I checked at the time and when I went into the Add-On Manager, it didn't say any updates were available, so I assumed I was all updated.
I had restarted FreeCAD between the time I checked the first time and and when I checked again just now, and now I had two updates available. Updated them and now we are good.
So does the Add-On manager only check for updates after a restart?
PAS_Drafter wrote: Wed Aug 17, 2022 6:28 pm So does the Add-On manager only check for updates after a restart?
I don't think so, but there were issues with AddonManager. I have removed and reinstalled my addons, and now it works as expected.
