Hello folks.
Is there any way that I can check for interferences? For instance, after using A2Plus, Assembly3 or Assembyl4. Or maybe even using a manual approach to assemble a design. Is there any way or routine, workflow, macro, or any idea how can I do to check interference between parts?
I appreciate the discussions here, thank you.
Checking for interference
Re: Checking for interference
I don't know of something automatic, but you can do a boolean Common, and check whether the result is empty.
Interesting. When you say, Boolean Common is that the Boolean Intersection?
Boolean common is what it says: what both elements have in common. If that is "something" (i.e. not empty), they intersect.
Cheers,
Markus
Markus
You can use this tool: Part SectionCut. Currently, it's side effect is that intersecting objects are not cut so it can be used to check for interference.
Yes, see Part Common.
Ah, I see. It is the intersection, then. Thank you.
- Screenshot-20220818213645-413x188.png (19.36 KiB) Viewed 882 times
I have asked this a long time ago but I could finally implement something for Asm4.
Colored parts are the ones conflicting.
Thanks for sharing this solution ChrisB.
