Opening an fcstd file that contains an iges import causes memory overflow and system crash
thomas-neemann
Post by thomas-neemann »
opening an fcstd file that contains an iges import
https://grabcad.com/library/g3-model-in-igs-format
Can anybody confirm this?
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
TheMarkster
Re: Opening an fcstd file that contains an iges import causes memory overflow and system crash
Post by TheMarkster »
Attach your fcstd file.
GeneFC
Post by GeneFC »
I downloaded the file and imported it into a new project. Took a while but no problems.
The IGES file is pretty large, 130 MB, so that might be the problem. Also, as The Markster hinted, your FCStd file might be contributing.
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.21.29849 (Git)
Branch: Master
Hash: 790bf5363e05c3de35d3c1350fd887b94f27a656
Installed mods:
  * FeedsAndSpeeds 0.4.0
  * FeedsAndSpeeds-master.zip
  * Help 1.0.3
  * offline-documentation
Gene
thomas-neemann
TheMarkster wrote: Thu Aug 18, 2022 9:26 pm ...
GeneFC wrote: Thu Aug 18, 2022 11:47 pm ...
here is the file
https://drive.google.com/file/d/18TxC45 ... sp=sharing
mfro
Post by mfro »
Congratulations, I think you have found a bug. There is no FreeCAD error message, just a syslog entry:
Out of memory: Killed process 251297 (FreeCAD) total-vm:11136448kB, anon-rss:6860712kB, file-rss:44144kB, shmem-rss:8896kB, UID:1000 pgtables:15132kB oom_score_adj:200
This is from my laptop (16 GB), more memory doesn't help, it just takes longer to crash (tested on an 128GB machine with plenty of swap as well).
OS: Debian GNU/Linux bookworm/sid (GNOME/gnome)
Version: 0.21.30120 (Git)
Branch: attach_to_wire
Hash: 882845e6318050ec3cb9cca702c240f83816a0aa
Python 3.10.5, Qt 5.15.4, Coin 4.0.0, Vtk 7.1.1, OCC 7.7.0.dev
Cheers,
Markus
thomas-neemann
mfro wrote: Fri Aug 19, 2022 6:24 am ...
thanks for testing. can someone test it on windows or mac os?
mfro
Post by mfro »
thomas-neemann wrote: Fri Aug 19, 2022 6:29 am
Read @GeneFC's post.
Cheers,
Markus
thomas-neemann
mfro wrote: Fri Aug 19, 2022 6:36 am ...
i did that, i understood it that he only imported the igs file, but didn't save it as fcstd and reload it
mfro
Post by mfro »
thomas-neemann wrote: Fri Aug 19, 2022 6:39 am i did that, i understood it that he only imported the igs file, but didn't save it as fcstd and reload it
Ah, o.k. For me, just trying to import the IGES file is enough to crash.
Cheers,
Markus
GeneFC
Post by GeneFC »
OK, I tried a few different things. (All done independently.)
1. I created a new document as noted above and imported the IGES file. Took a couple of minutes, but the result looked OK.
2. I opened the FCStd file posted on Google Drive. It opened very fast, but the image was a bit broken up.
3. I saved the document (FCStd) that was created when I imported the IGES file directly. When I reopened that file the time was a few seconds, and the image was broken up in the same manner as test 2.
In each case I got an error message:
<Part> ViewProviderExt.cpp(1267): Cannot compute Inventor representation for the shape of g3_20#G3_body003: NCollection_AliasedArray::value(), out of range index
No crashes, but this is on Windows, which tends to capture events that cause crashes on Linux.
My guess is that the IGES file has a problem, and FreeCAD may not deal with the model correctly when saving.
[Edit: Played a bit more. The simple imported IGES file shows many errors in the "Check" mode. In particular the shape G3_body003 has hundreds of errors. This is with BOP check OFF. If BOP check is ON there are even more errors.]
Gene
