thanks for the cooperation. defective import files can always occur again. freecad is not to blame for that. freecad should not crash and certainly not crash the entire system. If this error cannot be fixed or is not fixed, I would recommend doing imports (under linux) in a virtual box
Opening an fcstd file that contains an iges import causes memory overflow and system crash
- thomas-neemann
Re: Opening an fcstd file that contains an iges import causes memory overflow and system crash
No crash here, same error:
<Part> ViewProviderExt.cpp(1267): Cannot compute Inventor representation for the shape of g3_20#G3_body003: NCollection_Array1::Value
The wait cursor remained after the file was finished loading until I moved the mouse cursor, leading me to think the loading had not yet finished.
OS: Windows 10 (10.0)
Version: 0.21.29485 (Git)
Hash: a236ca843fdd6674afb6d7ed1454fbd3b547f5ea
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Installed mods:
* A2plus 0.4.56a (Disabled)
* Assembly4 0.12.3
* BOLTSFC
* CurvedShapes 1.0.4
* Curves 0.3.0
* DynamicData 2.46.0
* fasteners
* FCGear
* frame 0.1.0
* FreeCAD_mcm_addon
* gears
* hfcInventorMentorA
* InvGears
* lattice2
* Manipulator
* MeshRemodel 1.8919.0
* POV-Ray-Rendering
* sheetmetal 0.2.54
* ThreadProfile 1.82.0
I tried running it in a debugger inside a Virtualbox VM (Ubuntu guest, windows host). I got the same error message in the report view. I could not see anything in the 3d view, but could see the bodies in the combo view. Entire guest OS became unresponsive for a few seconds, then FreeCAD simply closed. The debugger did not present the location of the crash as it usually does. In the console the message "Killed" was displayed. My guess is the system killed FreeCAD due to out of memory issues, but that's only a guess. I have 5177MB allocated to the guest, 16GB system total.
- thomas-neemann
