Revolution not showing up but no error ? [Solved]
FredCailloux
Post by FredCailloux »
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Locale: French/Canada (fr_CA)
A Body is built with two Lofts and finally a Revolution.
For some reason the Additive Revolution is not showing up on the Rendering window.
This should be an easy object that was done many times before.
I tried to toggle the Reverse parameter, still nothing is showing up.
What am I doing wrong ?
PinceAligatorPouch.FCStd
(87.15 KiB) Downloaded 10 times
Great results only comes with great understanding. Great memory is just an illusion.
Bance
Re: Revolution not showing up but no error ?
Post by Bance »
The error is in the second loft, you must draw the inner and outer profiles correctly.....
https://wiki.freecadweb.org/PartDesign_ ... Loft#Notes
Here is another thread with the same problem:-
https://forum.freecadweb.org/viewtopic.php?f=8&t=71055
Shalmeneser
Post by Shalmeneser »
:idea:
Capture d’écran 2022-08-19 075722.jpg (39.95 KiB) Viewed 502 times
PinceAligatorPouch_SHALM.FCStd
(81.78 KiB) Downloaded 7 times
FredCailloux
Shalmeneser wrote: Fri Aug 19, 2022 5:58 am:idea:
Thanks for the example. I clearly see where my mistake was.
