PositionBySupport: AttachEngine3D::calculateAttachedPlacement: Frenet-Serret normal is undefined. Can't align to TN plan
leoheck
Post by leoheck »
What does this mean? How do I locate this thing, how do I fix it?
22:03:12  PositionBySupport: AttachEngine3D::calculateAttachedPlacement: Frenet-Serret normal is undefined. Can't align to TN plane.
leoheck
Re: PositionBySupport: AttachEngine3D::calculateAttachedPlacement: Frenet-Serret normal is undefined. Can't align to TN
Post by leoheck »
Extra view of the Report View after opening this file.
22:02:58  Path WB not found
22:03:12  AttachEngine3D::calculateAttachedPlacement:InertialCS: inertia tensor has axis of symmetry. Second and third axes of inertia are undefined.
22:03:12  AttachEngine3D::calculateAttachedPlacement: path curve second derivative is below 1e-14, can't align x axis.
22:03:19  AttachEngine3D::calculateAttachedPlacement:InertialCS: inertia tensor has axis of symmetry. Second and third axes of inertia are undefined.
user1234
Post by user1234 »
File? How do you produce the error? What version? Any extra WB since that seems no FreeCAD default error message?
edwilliams16
Post by edwilliams16 »
The error message is saying you are trying to do a Frenet attachment on a straight line. That can't be done because only curved lines have a well-defined normal direction.
leoheck
Post by leoheck »
edwilliams16 wrote: Fri Aug 19, 2022 2:28 am The error message is saying you are trying to do a Frenet attachment on a straight line. That can't be done because only curved lines have a well-defined normal direction.
How do I get extra info of this on a big file with a lot of other things inside? I would like to locate the Object/Feature/Sketch/Operation. Is it possible somehow?
user1234 wrote: Fri Aug 19, 2022 1:36 am File? How do you produce the error? What version? Any extra WB since that seems no FreeCAD default error message?
Hi. The version of what you ask? The version of Freecad is 0.21.
I think I am using the following workbenches but may have some others that I am not aware of.
- Assembly4
- Part Design Workbench
- Sketches
- Fasteners Workbench
leoheck
Post by leoheck »
user1234 wrote: Fri Aug 19, 2022 1:36 amFile?
For the limited minds. This is the file.
https://www.dropbox.com/s/dcv1ubxnbddh8 ... FCStd?dl=0
See, I am not asking for you guys to "find the culprit" and fix it for me.
I am asking "HOW do you find/identify the culprit Object/Feature/Operation since the f* message is generic af?"
Shalmeneser
Post by Shalmeneser »
leoheck wrote: Fri Aug 19, 2022 6:26 pm Hi. The version of what you ask? The version of Freecad is 0.21.
Provide your FULL version as asked in the red banner link.
user1234
Post by user1234 »
leoheck wrote: Fri Aug 19, 2022 6:38 pm
Oh, awaiting help, but insult the helpers. How about to read the links in the read box and think about your behavior and how helping works, since we are no wizards with a glass orb.
leoheck wrote: Fri Aug 19, 2022 6:38 pm See, I am not asking for you guys to "find the culprit" and fix it for me.
How to avoid the error you ask, just do not make the error ....... what the f*ck there are people .......
onekk
Post by onekk »
- Assembly4
- Sketches
Please follow guidelines in:
http://forum.freecadweb.org/viewtopic.php?f=3&t=2264
Regards
Carlo D.
- Various other stuffs.
