Simple geometry generation error
Hello, I'm using Freecad sometime, so I'm not so skilled to use it.
I met a difficulty with very simple geometry, I'm using:
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Locale: C/Default (C)
The geometry I would want obtain is in fig. 1
I drawn the sketch (fig. 2) with no DoF bat when I try to do the Pad always the following message is shown:
Recompute failed! Please check report view. (the large curves are drawn wit h 3 point tool)
I solved the problem importing a sketch geometry from a dxf, generated in a 2D CAD system.
I'm thinking to do a very stupid error, can you explain me what may be my mistakes.
Thank you
Regards
Thank you
Regards
- Fig. 2
- two.gif (13.48 KiB) Viewed 942 times
- Fig. 1
- one.gif (3.19 KiB) Viewed 942 times
- thomas-neemann
Re: Simple geometry generation error
Hello, if you can attach the file it would be easier to find out the issue.
It seems that there is some line overlapping other lines. Maybe where the arrows point
It's just a poor constraints scheme.....
- hinge.FCStd
- (7.38 KiB) Downloaded 17 times
Attached needed file
- prova.FCStd
- (7.37 KiB) Downloaded 20 times
Bance gave you the solution.
My comment was wrong, there are no overlapping lines. Sorry for the noise.
- thomas-neemann
When I try to pad the sketch I get the message "Wire not closed". The Sketcher's validation tool show the vertex in question. An automated repair will of course create overconstraints. You have created something like a "homemade tangency" by using two point-on-line constraints. Remove them, and create a point-to-point tangency.. As this consumes 3 degrees of freedom you have to remove another constraint, e.g. one of the radii at the left.
I recommend to use the same tangency for the other similar vertices as well.
If you need it, I can upload the file.
- Shalmeneser
Sketcher_ValidateSketch > Highlight troublesome vertexes :
* problems with left edge of 70mm line (suppress the Sketcher_ConstrainPointOnObject, add Sketcher_ConstrainCoincident)
But the sketch is not perfect.
- Capture d’écran 2022-08-19 194019.jpg (43.03 KiB) Viewed 740 times
- prova_SHALM.FCStd
- (12.9 KiB) Downloaded 12 times
Thanks to all.
Regards
Regards
