adrianinsaval wrote: ↑Mon Sep 05, 2022 12:17 pm Seems you have some sort of permission error, you should run it with the --write-log option an upload the log
- freecad.AppImage -c --write-log "print(2+2)" 2>&1
File exists and file size matches, skipping File exists and file size matches, skipping [... a lot more of that ...] qt.qpa.xcb: could not connect to display qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found. This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem. Available platform plugins are: eglfs, minimal, minimalegl, offscreen, vnc, webgl, xcb. /tmp/appimage_extracted_8cac30c456e0f6469e8601386557085d/AppRun: line 42: 2914 Aborted ${MAIN} "$@"
- freecad.AppImage freecadcmd -c --write-log "print(2+2)" 2>&1
File exists and file size matches, skipping File exists and file size matches, skipping [... a lot more of that ...] Initialization of FreeCAD failed: While initializing FreeCAD the following exception occurred: 'Could not create directories. Failed with: Permission denied' Python is searching for its runtime files in the following directories: /tmp/appimage_extracted_8cac30c456e0f6469e8601386557085d/usr/lib/python39.zip:/tmp/appimage_extracted_8cac30c456e0f6469e8601386557085d/usr/lib/python3.9:/tmp/appimage_extracted_8cac30c456e0f6469e8601386557085d/usr/lib/python3.9/lib-dynload Python version information: 3.9.13 | packaged by conda-forge | (main, May 27 2022, 17:07:55) [GCC 10.3.0] The environment variable PYTHONHOME is set to '/tmp/appimage_extracted_8cac30c456e0f6469e8601386557085d/usr'. Setting this environment variable might cause Python to fail. Please contact your administrator to unset it on your system.
- python2 -c "print(2+2)" 2>&1
4
