FreeCAD 0.20.1: impossible to save on SMB share with Windows11
mbordoni
Post by mbordoni »
With:
OS: Windows 10 Version 2009
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Locale: Italian/Italy (it_IT)
If you try to save a project to an SMB share you get the following error: "boost::filesystem:weakly_canonical: The specified path is invalid"
In reality the path use is working perfectly and it has been selected via "Save As" dialog.
In attach the screen dump of the error dialog.
How to fix this?
Save As Error
Save As Error
WindoAC
Re: FreeCAD 0.20.1: impossible to save on SMB share with Windows11
Post by WindoAC »
thomas-neemann
Post by thomas-neemann »
mbordoni wrote: Sat Sep 10, 2022 5:02 pm ...
nfs is better than smb (also from a security point of view). that would be a quick solution (workaround)
adrianinsaval
Post by adrianinsaval »
is the same problem present if you use the 0.21 dev builds? https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds if yes, does it work with 0.19.4?
WindoAC
Post by WindoAC »
adrianinsaval wrote: Mon Sep 12, 2022 3:56 pm is the same problem present if you use the 0.21 dev builds? https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds if yes, does it work with 0.19.4?
Great! Test "FreeCAD_weekly-builds-30345-2022-09-11-conda-Windows-x86_64-py310.7z" save to SMB share path no issue.
Version: 0.21.30345 (Git)
Hash: f42a47aa0fd8c4f34ef63c185d9f29b9b6e84737
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
>>> ### Begin command Std_Save
>>> Gui.SendMsgToActiveView("Save")
>>> App.getDocument("Unnamed1").saveAs(u"//cheong-ds920/temp/test1.FCStd")
>>> ### End command Std_Save
adrianinsaval
@wmayer @uwestoehr it seems something was fixed regarding this in 0.21, do you know when and if it was backported to the 0.20 branch? This looks like something related to that change to follow symlinks when saving
adrianinsaval
wmayer wrote: Wed Sep 14, 2022 1:52 pm master: git commit 84eb5fe9e219
0.20 branch: git commit c00740aa151
hhhmmm according to OP it doesn't work in 0.20.1 though, which should include that change.
mbordoni
Post by mbordoni »
I tried weekly build https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds and it works fine.
Since it is a major issue it would be needed either a hotfix to 0.20.1 current official release or a 0.20.2 version.
What would you think it is going to happen?
Bests
adrianinsaval
we first need to identify what exactly makes this work in one but not in the other, the 0.20.1 version you are running is from the installer right? could you try if the problem also exists in the conda build of 0.20.1? https://github.com/FreeCAD/FreeCAD/rele ... 4-py310.7z
