Failure with import - single path of several will not close/wrong "fill"
sdaau_ml
Post by sdaau_ml »
Hi all,
I use:
OS: Ubuntu Core 20 (MATE/mate)
Version: 0.20.1.29177 +233 (Git) Snap 245
Branch: tag: 0.20.1
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.8.10, Qt 5.15.3, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.3
Consider the following .svg:
test.svg
(2.8 KiB) Downloaded 19 times
When I try to start a new FreeCAD file, then click File / Import and try to import the above SVG as "SVG as geometry (importSVG)", I get this:
So, for some reason, that which got imported as path1096001, has apparently imported the points correctly - but does not have an outline, and has like a "square fill" instead - and when I try to extrude this path later, the extrusion is not closed, but instead that square fill hovers over the hole.
What is the problem here, and how do I get all paths to import correctly in FreeCAD?
Screenshot at 2022-09-26 10-55-44.png (134.84 KiB) Viewed 268 times
thomas-neemann
Re: Failure with import - single path of several will not close/wrong "fill"
Post by thomas-neemann »
sdaau_ml wrote: Mon Sep 26, 2022 8:59 am ...
can you upload the file from which the svg was created?
Roy_043
Post by Roy_043 »
There is something wrong with the path in question. It has two superimposed points.
