is it possible to set a radiant constraint instead of an angle constraint in the sketcher? The same for the polar pattern.
In my part it would be easier to set a distance at the arc in mm instead of an angle.
Radiant constraint
Radiant constraint
- 1.png (86.46 KiB) Viewed 474 times
Re: Radiant constraint
I don't know what a radiant constraint is?
But if it refers to using Radians rather than degrees, simply force the unit by entering E.G 1 rad instead of 57.29 deg
Thanks.
Maybe this radian constraint could look like this:
- 2.png (27.16 KiB) Viewed 430 times
You can do this by using expressions.
In this case the angle subtended by an arc of 30mm = 30/280 rad or more generally s/r where s = arc length, r = radius of arc.
- Bildschirmfoto 2022-09-26 um 23.55.18.png (62.52 KiB) Viewed 393 times
