Hello,
I tried to revolve Sketch081 with DatumLine002 and 360°.
The same with Sketch083 and DatumLine002.
I always get a calculation error.
Revolution on DatumLine
- pipe.FCStd
- (755.92 KiB) Downloaded 16 times
- 1.png (58.63 KiB) Viewed 305 times
Re: Revolution on DatumLine
It's a co-planar issue, you may search the forum for a deeper explanation.
Basically it is a rounding error in computation, you can workaround by making the revolution before the pocket, and adjusting such that the pocket has a different diameter than the ID of the revolve.
- revolve.png (69.07 KiB) Viewed 292 times
Seems to be a coplanar issue. It works with a slightly modified sketch moving the revolve up the tree:
Edit: crosspost with Bance.
I removed the last pattern to reduce the filesizeEdit: crosspost with Bance.
- pipe_cb.FCStd
- (900.89 KiB) Downloaded 14 times
