Revolution on DatumLine
anno15
Post by anno15 »
I tried to revolve Sketch081 with DatumLine002 and 360°.
The same with Sketch083 and DatumLine002.
I always get a calculation error.
pipe.FCStd
(755.92 KiB) Downloaded 16 times
Bance
Re: Revolution on DatumLine
Post by Bance »
It's a co-planar issue, you may search the forum for a deeper explanation.
Basically it is a rounding error in computation, you can workaround by making the revolution before the pocket, and adjusting such that the pocket has a different diameter than the ID of the revolve.
Seems to be a coplanar issue. It works with a slightly modified sketch moving the revolve up the tree:
I removed the last pattern to reduce the filesize
Edit: crosspost with Bance.
pipe_cb.FCStd
(900.89 KiB) Downloaded 14 times
