How do I fix a part that has this plane appearing?
leoheck
Re: How do I fix a part that has this plane appearing?
Post by leoheck »
domad wrote: Tue Sep 27, 2022 8:21 pm Hi leoheck, hello to the Community!
- Wb "Part"
- select "Skeleton-YB1.1-Top_Bottom_Complete_Clean"
- "Part" menu -> Compound -> Explode compound
Hello, domad. This is interesting.
However, it does not work still, see:
As the others are saying it may be a bug in this version.
leoheck
Post by leoheck »
Roy_043 wrote: Tue Sep 27, 2022 8:22 pm Another easy solution:
Use the "set Tolerance value" button from the Defeaturing_Workbench.
Thanks Roy. This did not work for me.
I am testing with Defeaturing WB (1.2.0)
Results from the left to the right.
Roy_043
Post by Roy_043 »
leoheck wrote: Tue Sep 27, 2022 8:42 pm This did not work for me.
You are right, it does not work, the face disappears on the outside, but not on the inside.
leoheck
Post by leoheck »
adrianinsaval wrote: Tue Sep 27, 2022 7:31 pm I doubt grabcad uses occt, is it originally a step file? could be a bug during import or just a bad file. As for fixing, I suggest cutaway the buggy section and redo:
lala.FCStd
it still has a lot of geometry check errors though.
adrianinsaval, your technique worked for me. This is good! It works even after converting it to a Simple Copy. The simple copy does not give me errors.
Thanks for helping me out.
adrianinsaval wrote: Tue Sep 27, 2022 7:31 pm As for fixing, I suggest cutaway the buggy section and redo:
Yes, indeed, redesigning this would be better and it is not hard. However, I would like to know how to fix these things quickly because sometimes I find parts with this kind of issue and I don't have too mutch time to redesign everything.
leoheck
Post by leoheck »
The intersection between the part you have fixed, with the problematic one, is this area highlighted here. So this is the problematic point.
Thanks again for helping me to understand how to fix this.
