How do I fix a part that has this plane appearing?
leoheck
Post by leoheck »
Hello folks, I have this issue with a part where a plane is appearing out of nowhere.
I tried some operations adding material and then removing material but I could not fix this issue.
Any ideas on how do I fix this part?
Thanks in advance.
OS: Ubuntu 22.04.1 LTS (ubuntu:GNOME/ubuntu)
Version: 0.21.30430 (Git) AppImage
Hash: 9e1ed4a68ad43309c2b38f7f5efbb1feac4323cb
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Installed mods:
  * Part-o-magic.backup1662467294.9039905
  * A2plus 0.4.59
  * Curves 0.5.8
  * fasteners 0.4.6
  * lattice2 1.0.0
  * Assembly4 0.12.4
  * kicadStepUpMod 10.15.1
  * Help 1.0.3
lala.FCStd
(67.06 KiB) Downloaded 21 times
Roy_043
Re: How do I fix a part that has this plane appearing?
Post by Roy_043 »
Where the rectangular face meets the solid there are two edges. One is a circle, the other a B-spline. They are almost superimposed, but not quite. I suspect that is the cause of the rogue face. How this came about is hard to tell with only a shape without any history.
leoheck
Post by leoheck »
Yeh, this part has no history at all. But the cause is not a big deal for me.
Do you know a possible fix for that?
leoheck
Post by leoheck »
For instance, online, on GrabCad. It does not have issues at all. Maybe Freecad is interpreting something extra, here. Or maybe GrabCad is ignoring something.
leoheck
Post by leoheck »
This one is a second test.
Tube-v2 was another try to fix this.
Then with Part Design, I could fix it.
But then when creating a simple copy of it, it creates this face.
Side by side comparison
On the left we see the part design version of it. On the right, the simple object created with the one fixed in Part Design.
tube2.FCStd
(260.48 KiB) Downloaded 10 times
Roy_043
Roy_043
Post by Roy_043 »
The easiest solution is to cut away a very thin layer from the outside with a Part_Tube and Part_Cut.
lala_cut_tube.FCStd
(153.36 KiB) Downloaded 10 times
Syres
Post by Syres »
leoheck wrote: Tue Sep 27, 2022 1:27 pm Hello folks, I have this issue with a part where a plane is appearing out of nowhere.
This is a perfect example of why we repeatedly ask for the FULL INFO, if you had done this it would have been mush easier to show that the version of OCCT is the root cause.
Works fault free using:
OS: Linux Mint 20.3 (X-Cinnamon/cinnamon)
Version: 0.21.30479 (Git)
Hash: 5a14ff96f4e2ba139382672dc34ca236f3b361dc
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.3.0
Installed mods:
  * ThreadProfile 1.83.0
  * A2plus 0.4.59
  * Curves 0.5.8
  * ExtremeProDark 1.0.4
  * Plot 2022.4.17
  * fasteners 0.4.6
  * sheetmetal 0.2.57
Fails using:
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.3
Installed mods:
  * A2plus 0.4.59
  * Curves 0.5.8
  * Plot 2022.4.17
  * fasteners 0.4.6
  * sheetmetal 0.2.57
See the difference????
adrianinsaval
Post by adrianinsaval »
I doubt grabcad uses occt, is it originally a step file? could be a bug during import or just a bad file. As for fixing, I suggest cutaway the buggy section and redo:
lala.FCStd
(188.61 KiB) Downloaded 13 times
it still has a lot of geometry check errors though.
domad
Post by domad »
leoheck wrote: Tue Sep 27, 2022 1:27 pm ....
Hi leoheck, hello to the Community!
- Wb "Part"
- select "Skeleton-YB1.1-Top_Bottom_Complete_Clean"
- "Part" menu -> Compound -> Explode compound
lala_domad.FCStd
(165.24 KiB) Downloaded 10 times
Roy_043
Post by Roy_043 »
Another easy solution:
Use the "set Tolerance value" button from the Defeaturing_Workbench.
