How to reference document/global properties?
naasking
Post by naasking »
I typically use spreadsheets to setup dimensions and some computed values, but I thought I'd give properties a try. I have a number of dimensions that I want shared across a few different parts in a project, so I thought I'd define them as properties on the document root:
Freecad props 2022-09-29 085430.png (27.45 KiB) Viewed 1131 times
But I can't seem to figure out how to reference those properties when working on an actual part in part design, and the autocomplete doesn't seem to produce anything useful here:
FreeCAD props 2022-09-29 085512.png (33.77 KiB) Viewed 1131 times
Obviously I can define these properties on the part itself and then reference them as DIMS_WallThickness, etc. but since many of these properties will be shared across multiple parts, I wanted to add them to an object that wasn't connected to any particular part in case that part gets removed as I iterate. What is the right pattern here if I want to do this with properties and not spreadsheets?
OS: Windows 10 Version 2009
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Installed mods:
  * fcgear 1.0.0
Shalmeneser
Re: How to reference document/global properties?
Post by Shalmeneser »
*SpreadSheet
* Master Sketch
* DynamicData Workbench
naasking
Post by naasking »
Thanks, but a big reason I'm trying to avoid spreadsheet is that it becomes unbearably slow after I add about 20 entries. I mean it takes 5-10 seconds for every change to complete.
vm4dim
Post by vm4dim »
May use dedicated blank element (for example Group) in root as "Property Keeper"
vm4dim wrote: Fri Sep 30, 2022 10:24 pm May use dedicated blank element (for example Group) in root as "Property Keeper"
It may not be relevant, but such models are rather difficult to understand by others. As DynamicData does exactly this, I'd prefer that, because it clearly states what i is.
drmacro
Post by drmacro »
chrisb wrote: Fri Sep 30, 2022 10:58 pm
I'll second what chrisb says. DD is way under appreciated and underutilized. It is lightweight compared to spreadsheets.
kisolre
Post by kisolre »
Still the question remains: You can define properties. How do you access them?
kisolre wrote: Sat Oct 01, 2022 10:15 pm can define properties. How do you access them?
You can use them in Expressions.
kisolre
Post by kisolre »
chrisb wrote: Sat Oct 01, 2022 10:16 pm You can use them in Expressions.
We all know that :) But how? In the wiki page under "Document-wide global variables" there is a mention that there are no such variables. But those are clearly such, they can be created, modified, deleted, ... The problem is how to access them?
You can reference an object by its DataName or by its DataLabel.
What are those for the document itself? What to put between the << >>?
kisolre wrote: Sat Oct 01, 2022 10:15 pm You can define properties. How do you access them?
It seems I don't understand the question. The DynamicData documentation shows how to access the dd values.
