Difference between Part Import CAD and File>Import
drmacro
Post by drmacro »
To quote a question posed on another social media platform:
"Can anyone explain the difference between Part workbench -> Part -> Import CAD, vs just File->Open for a step file?
if I open a vendor step file, it's all transparent, and I can't apply colours or materials, If I "Import CAD" it comes in properly, and can be re-saved nicely for use in kicad for isntance."
easyw-fc
Re: Difference between Part Import CAD and File>Import
Post by easyw-fc »
drmacro wrote: Fri Sep 30, 2022 12:43 pm To quote a question posed on another social media platform:
which are your STEP import settings?
have you a step file to test & display?
drmacro
Post by drmacro »
Again, quoting the OP on Discord:
"I've tried all the tickboxes on preferences for step import though, and I can only make it worse. I mean. I can move on with my life for this part having it imported and re-exported, wsa just hoping to find out what I would noramlly use this "import cad" option for..."
I've asked him if he can provide the file...
drmacro
Post by drmacro »
Hmm...so it is as he says. On the left File>Import and on the right Part>Import CAD:
Snip macro screenshot-9f86a4.png (93.04 KiB) Viewed 758 times
The step file is too big for the forum, so: https://ttm.sh/qgt.stp
easyw-fc
Post by easyw-fc »
for what I see it seems there is only a different Draw style ( the first one is wired)
https://wiki.freecadweb.org/Std_DrawStyle
drmacro
Post by drmacro »
easyw-fc wrote: Fri Sep 30, 2022 7:09 pm for what I see it seems there is only a different Draw style ( the first one is wired)
Nice try. ;) But, the draw style on both is As is.
And, no changes in the preferences on the File>Import one changes what you see.
easyw-fc
Post by easyw-fc »
please post your full FC release version...
I can reproduce the issue and also a different one changing FC version and import settings...
It seems the best is when using Assembly3 Link branch
Edit:
Part Import and Open Step file are using the legacy and the new STEP parser code routines.
easyw-fc
Post by easyw-fc »
it seems the model is done as a combination of shells instead of solids
I have exported the file from LinkBranch as Step, imported in FC Main, make solids from the resulting importing shells and this is the model resulting
qgt-exported.step.zip
(388.06 KiB) Downloaded 12 times
qgt-solid.step.zip
(251.65 KiB) Downloaded 13 times
FC has had frequently issues in handling shell step objects
qgt-shells-issue-loading.zip
(635.5 KiB) Downloaded 10 times
drmacro
Post by drmacro »
easyw-fc wrote: Fri Sep 30, 2022 7:57 pm please post your full FC release version...
I'm using (Debian11) 0.21 (30492) with OCC 7.7. The person who asked is on 20.1 appimage (fedora36).
Edit:
Hmm...is there, or could there be, a list of tips on effective use and trouble shooting of step usage?
easyw-fc
Post by easyw-fc »
drmacro wrote: Sat Oct 01, 2022 3:32 pm Hmm...is there, or could there be, a list of tips on effective use and trouble shooting of step usage?
I don't think it exists at the moment...
STEP is a real white rabbit hole :D
