[bug] Sketcher dimension numbers not visible from the back.
openBrain
Re: [bug] Sketcher dimension numbers not visible from the back.
Post by openBrain »
@uwestoehr can you reproduce with the Windows build? Thx
kisolre
Post by kisolre »
Same build on another PC gives same result.
OS: Windows 10 Version 2009
Version: 0.21.30485 (Git)
Hash: 8924e265c068c2446a091f84c83c8b1934451470
Python 3.8.8, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Locale: Bulgarian/Bulgaria (bg_BG)
Installed mods:
  * 3DfindIT
  * 3D_Printing_Tools
  * A2plus
  * AirPlaneDesign
  * ArchTextures
  * Assembly4
  * Autoload
  * BCFPlugin
  * BIM
  * BIMBots
  * bimtester
  * BOLTSFC
  * CurvedShapes
  * Curves
  * Defeaturing
  * DesignSPHysics
  * dodo
  * DynamicData
  * ExplodedAssembly
  * fasteners
  * fcgear
  * kicadStepUpMod
  * lattice2
  * LCInterlocking
  * MakerWorkbench
  * Manipulator
  * MeshRemodel
  * MOOC
  * nurbs
  * ose-piping
  * OSE3dPrinter
  * Part-o-magic
  * parts_library
  * Plot
  * Pyramids-and-Polyhedrons
  * pyrate
  * Reinforcement
  * sheetmetal
  * Ship
  * Silk
  * SlopedPlanesMacro
  * symbols_library
  * ThreadProfile
  * trails
  * workfeature
Syres
Post by Syres »
kisolre wrote: Sun Oct 02, 2022 11:05 am New file.
New sketch.
Draw rectangle.
Create dimension - Ok.
Rotate view from back - dimension number dissapears.
Create dimension while still looking from the back - dimension is created but the number is not visible.
Rotate view to front - both dimension numbers are visible.
Dimension numbers always visible throughout using (Conda build maybe worth you trying to eliminate Coin version):
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.21.30492 (Git)
Hash: b4578fb3eae842eb510a1bc055d07d369a67ce94
Python 3.8.13, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Installed mods:
  * A2plus 0.4.56a
  * Assembly3 0.11.3
  * CfdOF 1.17.7
  * Curves 0.5.4
  * fasteners 0.3.51
  * fcgear 1.0.0
  * freecad.xray 2022.4.17
  * Manipulator 1.4.9
  * Plot 2022.4.17
  * sheetmetal 0.2.57
  * Silk 1.0.0
  * timber
NVidia GeForce GTX 670
09:58:22  OpenGL version is: 4.6 (4.6.0 NVIDIA 471.41)
09:58:22  Run Gui init script
09:58:22  Init: Running FreeCADGuiInit.py start script...
Exactly the same hardware but Linux boot partition also shows dimension numbers always visible:
OS: Linux Mint 20.3 (X-Cinnamon/cinnamon)
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.3
Installed mods:
  * ThreadProfile 1.83.0
  * A2plus 0.4.59
  * Curves 0.5.8
  * ExtremeProDark 1.0.4
  * Plot 2022.4.17
  * fasteners 0.4.6
  * sheetmetal 0.2.57
10:12:57  OpenGL version is: 4.6 (4.6.0 NVIDIA 470.141.03)
10:12:57  Run Gui init script
10:12:57  Init: Running FreeCADGuiInit.py start script...
We have seen similar things due to graphics card/driver issues. I don't know if OpenGL is involved here, but you may try to switch to "Software OpenGL".
adrianinsaval
Post by adrianinsaval »
Can you check if you have perspective or parallel rendering enabled while sketching? IIRC sketcher also has some rendering issues when in perspective mode.
openBrain
Post by openBrain »
I'm totally unable to reproduce ATM.
As @Syres, I also wonder about the Coin version. I hope problem isn't introduced by 4.0.1.
Hopefully we have enough people to test and report.
OS: Ubuntu 21.04 (KDE/plasma)
Version: 0.21.30511 +1 (Git)
Build type: Debug
Branch: textColor
Hash: 8bf7148ee0877a85a5cd82eafbfc845df1a6402d
Python 3.9.5, Qt 5.15.2, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.2
Locale: French/France (fr_FR)
kisolre
Post by kisolre »
adrianinsaval wrote: Mon Oct 03, 2022 1:08 pm Can you check if you have perspective or parallel rendering enabled while sketching? IIRC sketcher also has some rendering issues when in perspective mode.
Perspective shows another strange bug - when zooming in numbers become smaller and smaller until they disappear and only complete (without cut in the middle for the number) dimension line is visible. Same behavior from the back but without numbers - only space for them becomes smaller until it also disappears.
Tried some settings and found the problem - display settings/3d view/transparent objects = "Backface pass". If set to "One pass" numbers show properly. But this should not matter IMHO.
Now there is the perspective zooming of the numbers. Could there be some number size correction to keep them relative constant size when zooming in perspective mode which is set too high?
adrianinsaval
I don't know what's exactly the cause for the perspective bug but let's save that for the discussion for that bug. Sketcher was made to be used in parallel mode and I think it normally forces that mode when you edit a sketch. About backface pass, it kinda makes sense, I'm not sure in what situation you wouldn't want backface pass enabled? Perhaps it should be on by default and perhaps the option shouldn't be there anyways. Otherwise I'm not sure how this could be fixed.
openBrain
Post by openBrain »
kisolre wrote: Mon Oct 03, 2022 8:03 pm Perspective shows another strange bug - when zooming in numbers become smaller and smaller
Note for myself : due to scale computation here : https://github.com/FreeCAD/FreeCAD/blob ... #L436-L445
openBrain
Post by openBrain »
kisolre wrote: Mon Oct 03, 2022 8:03 pm Tried some settings and found the problem - display settings/3d view/transparent objects = "Backface pass". If set to "One pass" numbers show properly. But this should not matter IMHO.
:? Works correctly here whatever is this setting.
