GUI not working
GUI not working
I'm running Ubuntu 22.04 and tried installing FreeCAD from the software repositories. I found that the GUI was not showing correctly to the point of being unusable. I then removed that and downloaded the latest AppImage from the FreeCAD website (FreeCAD_0.20-1-2022-08-20-conda-Linux-x86_64-py310.AppImage) and unfortunately experienced the same issue. A screen shot is shown below. What can I do to debug this issue?
- Screenshot from 2022-10-01 21-35-45.png (10.38 KiB) Viewed 1298 times
Re: GUI not working
Hi and welcome to the forum!
Looks like an issue with the graphics card/driver. Did you check the Known OS specific issues?
Re: GUI not working
I figured it must be a graphics driver issue too. I'm using a fairly old card, a GeForce GTX 650 Ti Boost running the latest nvidia-driver-470 proprietary driver. I have no other issues with my graphics in any other programs.
I did notice that thread, but I didn't find anything that seemed to be relevant to my situation. However, I did dig deeper into the first time regarding fractional scaling. I don't use it, so I didn't think it was an issue. However, I decided to play with those settings a little bit and found out something weird! If I turn fractional scaling on and leave it at 100%, then there is no change. But if I have it on and scale the screen to 125%, then the FreeCAD GUI appears normal. So, there is some progress there! But I don't want to use fractional scaling, it causes other issues for my system (and I like the larger screen real estate without it). But at least this is some clue....
I have run many other programs through AppImage and other containers and never experienced an issue like this though.
Re: GUI not working
In case it is relevant, but screen has resolution of 2560x1440 with 96x96 dpi and 24 bit depth. It is a Dell U2713HM monitor connected via dual DVI.
And just changing the display resolution to other besides 2560x1440 (but with fractional scaling still off) does not fix the GUI issue. The only fix I can find is turning fractional scaling on and using something greater than 100%.
- adrianinsaval
Re: GUI not working
please post full version information as explained in the guidelines, this looks like a dpi issue. Where have you configured 96dpi? Where do you configure fractional scaling? Is this running under wayland? What is your DE? Several people running on xfce had this issue with a custom dpi setting.
Re: GUI not working
Here is the FreeCAD version information:
I'm running Ubuntu with GNOME and the fraction scaling options are part of gnome. I'm running X11 and I've never specially set the DPI - but the 96x96 is as reported by the NVIDIA driver. This information is available in the attached screenshots, as well as some additional information.
OS: Ubuntu 22.04.1 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.1.29410 (Git) AppImage
Branch: (HEAD detached at 0.20.1)
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
- Screenshot from 2022-10-03 20-47-07.png (35.21 KiB) Viewed 1007 times
- Screenshot from 2022-10-03 20-46-14.png (87.8 KiB) Viewed 1007 times
- Screenshot from 2022-10-03 20-47-37.png (68.98 KiB) Viewed 1007 times
Re: GUI not working
I doubt that this information is correctSpectre5 wrote: ↑Tue Oct 04, 2022 3:51 am ...
According to the information from Dell the physical dimensions of the panel is
Preset display area: 596.7 (H) X 335.7 (V) mm
Horizontal 596.7 mm (23.49 inches)
Vertical 335.7 mm (13.22 inches)
What is the output of
xrandr -q | grep connected
- adrianinsaval
Re: GUI not working
try some of the stuff from here: https://wiki.archlinux.org/title/HiDPI#Qt_5
check if one those options is already set. Check also the X Resources and X Server sections.
Re: GUI not working
Ah, I've found the culprit. In the Gnome Tweaks tool under the "Fonts" section there is a scaling factor for fonts. I have that set at 0.80 to reduce the font size on my screen. If I change this to 1.00, then FreeCAD displays correctly with fraction scaling turned off. I'd prefer to keep it at 0.80 instead of 1.0, but its a simple enough setting to change "on the fly" when using FreeCAD.
Thank you everyone for the helpful comments!
- adrianinsaval
Re: GUI not working
Doesn't Gnome have settings for font size??? Use that instead if it exist. Otherwise you could set the Qt specific env variables or edit your FreeCAD desktop files so it launches with those variables.
