OS: Linux Mint 21 (X-Cinnamon/cinnamon)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
I am wondering about a bunch of things:
a) should I start at x0/y0 with a corner of the box, or should I use 0,0 as centre point of the box (bottom plane)
b) I am asking a) because of the use of symmetry and mirrors (unless it is possible to position construction lines based on parameters; e.g. length / 2)
c) I'd like another movable body I can offset from the same corner for the posts to affix the Arduino. (Is this how the pros do it?)
d) I'd like multiple front panels I can switch on and off, with the holes for USB, Ethernet, Power connectors. I suspect this is done with multiple bodies that are switch on/off as required?!
For an analogy; when I started coding I got told to do this and that, and after a relatively short time, I figured the way I was told is not the best at times not even the proper approach. Things like proper naming of variables, coding and style guides, etc. Doing these things properly then allows other to maintain the code... and here allowing to help with a design, because it is properly set up, e.g. parametric, logical constraints, proper use of planes, etc. In short: building a model properly.
Also, I could not figure out how to start the lug (for the lid bolts) not at the bottom, but rather 20mm from their current recessed top plane. Any hints appreciated.
Are there any professional online courses, rather than basic user stuff people can recommend?
Probably an off-topic question: As for 3D printing these boxes, do people test print a few holes and see, whether they can screw into these without cutting threads; or are inserts being used to affix circuit boards?
